12 years 7 months ago #7048 by Wilf
I have used the app now and it works, except for the 'patch' page. How can I patch? There is no "=" button so I cannot say "[CH]23[@]45".
How should it work?
12 years 7 months ago #7049 by sl1200mk2
Replied by sl1200mk2 on topic Hexler TouchOSC - Remote for IPhone && Android
it's the '+' button
12 years 7 months ago #7052 by Wilf
The + and - button do not work.
12 years 7 months ago #7053 by sl1200mk2
the proper sentence is
XX Channel YY '+'
this patch the dimmer YY to channel XX.
I must admit I didn't investigate much the @mode way...
12 years 7 months ago #7054 by Wilf
There's the problem indeed. It works in the RPN-mode. I never use that mode because the @Mode is ideal in theater tour settings (for me).
12 years 7 months ago #7055 by sl1200mk2
ok, so let's say I fix the actual behavior (xx CHANNEL yy +) for it to work when @mode is selected, is it enough for u (u user of @mode)?
there's no pad in the patch channel so i cannot make it behave like the patch window of the soft.
do you imagine another solution?
12 years 7 months ago #7056 by Wilf
I would be really greatful if it would work in @Mode and I won't mind if that would be in RPN-style on the phone, so that would be great.
By the way: the room/universe button also only works in RPN-mode.
12 years 7 months ago #7059 by sl1200mk2
@Mode methods were not written... shame on me....
so now
[CH] xx [+] yy [ENTER] is equal to [CH] xx [@] yy [ENTER]
[CH] xx [-] yy [ENTER] is equal to [CH] xx [DELETE] yy [ENTER]
the problem you'll face is that the display area on the phone is small and you won't see the entire line...
unless you re-do the layout to fit your needs.
this changes will be available in the next beta witch I hope to publish today or tomorrow.
12 years 7 months ago #7066 by sl1200mk2
je veux affecter les services plateaux au sub1 et que ça reste allumé
il faut mettre le sub en mode TIME, comme ça il reste levé
d'autre part, j'ai effacé le gr1 affecté au sub1, comment retrouver le gr 1 pour le ré-affecter au sub1?
si t'as effacé le groupe1, il n'existe plus et tu ne peux plus le retrouver.
si tu l'as juste enlevé du sub, ouvre le GROUP listing et fais un glisser-déposer du groupe vers le sub.
12 years 7 months ago #7069 by sl1200mk2
3.0.17_b7 is available with the changes
The following user(s) said Thank You: Wilf
12 years 7 months ago #7070 by ouzadia
super, bravo
mais comment je charge la 3.0.17 ?
sur le site je ne trouve rien, 0 download, juste pour xquatrz et flash code
comment je fais pour garder les subs à full avec l'iphone (dès que je relâche le sub, ça revient à 0)?
12 years 7 months ago #7074 by sl1200mk2
pour télécharger la beta, tu va dans Download/beta.
la 30.17 est pas encore publiée.
tu mets tes subs en mode TIME
The following user(s) said Thank You: ouzadia
12 years 7 months ago #7078 by Wilf
In my best French: Tu es très magnifique!
12 years 7 months ago #7084 by ouzadia
3.0.17 beta downloaded,
oh le boulet, dans download/software, j'ai vu 0/5, donc j'ai pensé aucun téléchargement dispo... pas assez curieux
subs en mode time, même résultat: quand je monte les subs dans D::light à full, la remote iPad monte aussi et dès que je touche le sub avec la remote ,le groupe tombe à 0
12 years 7 months ago #7190 by ranzini
bonjour
j'ai exactement le même problème que ouzadia quand je relache les faders des sub que j'ai mis en time ils reviennent a zero automatiquement
je ne trouve pas la solution et je m'arrache les cheveux ça fait 2 jours
je suis certain que c'est encore un truc de base, mais j'ai pas trouvé
quelqu'un d'autre à déjà ce problème et la solution svp je suis en gallère total
Time to create page: 0.207 seconds
