DL4 request
if so, on wich sub?
and isn't it in solo mode?
- Wilf
- Thank you received: 3
[edit] I had two identical subs on different pages, one with solo and one without solo, and I revoked the wrong one [/edit]
- Wilf
Because sometimes I Freeze the cue to go to another cue somewhere sooner or later to edit it. And I have to remember exactly which cue number I was when i froze
:Light. So if somewhere on the screen there would be a field where the live (active) cue is shown this would take some risk out of blind editing Please Log in to join the conversation.
- quico
freezing is old fashion style... maybe you would prefer edit cues directly from the cue editor thus there's no need for freezing
@Quico
If I do so, it will pollute a lot the main window...
- Wilf
Freeze is like 'blind' on Compulite, which I've used many years before
:Light so it was the logical step. I'll look into cue window next time. Please Log in to join the conversation.
- nomatter
it would be great to have palette in chase and submasters, both flash and time.
In this way we can control devices with midi and timed.
If I select multiple devices in main window they all will appear in control windows (colour, beam, focus).
I think could be useful to be able to select them even in control windows to avoid repeated switching of windows.
And, I'm not sure if it's already possible, ability to type values in devices control windows (after clicking in the box)... I just found out the mouse wheel function.
Bye,
Carlo.
- Jefff
- Thank you received: 7
Qu'en pensez-vous ?
- Jefff
- nosmile
Je m'explique. J'utilise toujours l'export PDF afin de sortir une version papier de la conduite complête "au cas ou", en cas de grosse catastrophe (genre, PC et clef usb volé à 8h de route de chez moi et 3h avant une représentation) afin de pouvoir tenter de me demerder avec la console sur place. Mais je me rend compte que si les master link sont bien exporté, ce n'est pas le cas des FX. Serait-il possible des les ajouter à l'export PDF?
- birt
- Thank you received: 1
when i adjust intensities i just save and overwrite the cue i currently have on stage. this works well and easy.
but if at the same time a "wait" is running for the next cue it stops counting as soon as i overwrite the cue i'm in.
would it be possible to change this so it just keeps counting? that way the timing of follow-up cues in doesn't get messed up during rehearsal.
- Wilf
- birt
- leoclarys
- Thank you received: 10
Je reprends un spectacle sur lequel je dois lancer un CUE manuellement via crossfade et le suivant devrait se lancer automatiquement via un WAIT de 20sec. Pour l'instant le crossfade n'active pas le WAIT du CUE suivant, du coup je lance un GO avec un wait de 20 sec sur la montée et la descente. Ça fonctionne mais serait-il possible que le WAIT s'enclenche si on passe le Cue précédent en crossfade manuel?
