DL4 request
11 years 6 months ago #9831 by vbs
Replied by vbs on topic DL4 request
Hi,
Of course only dimmers, channels are in this case not importend.
Regards Vincent
11 years 6 months ago #9832 by nomatter
Replied by nomatter on topic DL4 request
I've never found a console where to assign a dimmer to more than one channel
So, I think, you're going right.
C.
11 years 6 months ago - 11 years 6 months ago #9835 by Wilf
Replied by Wilf on topic DL4 request
That's true, it would make Dlight unique, it was my request by the way. It's because I tour a lot and sometimes the theater I'm in doesn't have enough dimmers. Then I use one fixture for multiple instances. For example: channel 10 is a zoom special front on the right. Channel 24 is a small PC front on the right. If I have only one fixture I could call it ch 24 but I have to program ch 24 everywhere I usually use 10. This takes a lot of time, especially when one of the channels is also present in FX's, in time groups et cetera. Especially when you have more channels that play a double role. In those instances it would be nice to assign multiple channels to one dimmer.
I understand it's a niche and I wont mourn the lack. ;)
Cheers, Wilfred
Last edit: 11 years 6 months ago by Wilf.
11 years 6 months ago #9836 by Jefff
Replied by Jefff on topic DL4 request
Avoir 4 lignes de texte conduite comme il y a 4 lignes dans les steps....
11 years 6 months ago #9837 by Bestia Humana
Replied by Bestia Humana on topic DL4 request
Hi Wilf.
I understand you but I think there is a better way to do it.
Use the track window with both channels and in a few minutes you got it.
I believe that is better way than you can patch one dimmer to various channels.
Un saludo grande!!!
edu
WHEN MUSIC IS OVER
TURN OFF THE LIGHTS.
11 years 6 months ago #9838 by nosmile
Replied by nosmile on topic DL4 request
I agree with Wilf as I joined the request about multi channel to dimmer patch but this is quite tricky I agree...
But if it's implemented, there is also a need for a "channel curve".
Lets say you have 2 projecteur, one which is narrower than the other one but on the same point. You could remove the smaller one and use only the second one when you have a lack of dimmer or projector by using such feature. But to be correct, you'll also need a smaller DMX value for the smaller projector (for the same intensity...) Or you would use the channel inhibition feature but this cannot be if you have, eg, a neon combined with a halogen...
Another use for such feature (but much more rare and not always relevant) would be the case where you have a projector failure in show... If you have something else on the same space, you could use it via the multi channel to dimmer to prevent having a black spot... Quick and dirty :S but may be life saving...
11 years 6 months ago #9919 by shani
Replied by shani on topic DL4 request
joffo78 wrote: Hello.
Pas vraiment une nouvelle demande mais reformulée plus clairement :
Ce serait super d'avoir la possibilité à l'instar des Mlink d'avoir la possibilité de "linker"
à un pas de seq des message midi & OSC.
Par exemple pour l'osc, je créer un link osc, je saisi le texte de mon choix (ex avec resolume: /layer1/clip1/video/opacity/value) je saisi une valeur de départ, une valeur d'arrivée, un temps d'attente et un temps de montée.
Pour le midi : Je créer un message ctrl/note ou PGM ch (éventuellement sysex),un channel, une valeur 1 pour le numéro de contrôleur ou la hauteur de note ,une valeur 2 de départ, une valeur 2 d'arrivée , un temps d'attente et un temps de montée.
J'espère que tout cela vous parle.
Merci de votre attention.
JF
Oh que oui, comme le fais un autre soft que je ne citerais pas :)
Moi j'ai d'autres "request" et pas sur la beta que je ne test pas encore car je suis pas utilisateur d'auto.
En vrac, peut etre il y aura de bonnes mais aussi de mauvaises idées :
- j'ai toujours ce souci d'affichage avec windows qui ne me permet pas d'avoir dlight en pleine affichage, c'est assez contraignant...
- une idée : souvent les controleurs marche par serie de 8 fadeurs, ne serais t'il pas judicieux d'avoir par master page que 8 fadeurs? + 4 "indépendant" qui se retrouve toujours les mêmes sur chaque page? moi j'y trouverais bien mon compte comme ca, je sais pas vous?
-moi qui utile souvent deux ecran, et qui essaye de faire de l'acceuil avec (pas facile) il serait génial de pouvoir détacher le carré "output" de l'interface pour pouvoir la mettre en fenêtre indépendante la ou l'on veux, puis pouvoir mettre une autre fenêtre à la place (cue, sequence, ...) Dans l'idéal serais que toute les partis de l'interface soit détachable est independante (sub/control/outpout/...) et de pouvoir les réorganiser comme on le souhaite sur un ou deux ecrans. à la facon winamp pour ceux qui on connu...
- qu'il y ai à coté du Goback un mini case à cocher si l'on souhaite qu'il s'accorde au même temps qu'au go (goback in time)
- un deuxieme sequenciel independant où l'on pourrais charger en cour d'utilisation les cue et step d'un autre show, ou à default de pouvoir lancer plusieurs dlight en même temps. cela me permettrais pour de l'acceuil de ne pas tout jouer sur un seul show et de pouvoir enchaîner les spectacles sans quitter et relancer dlight, ainsi que sur certain spectacle complexe ou il y a des actions indépendante de pouvoir suivre l'un et l'autre sans difficulté...
- que quant on freeze le show avoir la possibilité de de-freezer en revenant à l’état lumineux qu'il y avait au moment du freeze
- Le go à un compteur de temps qui s’enclenche à chaque go... super j'adore mais souvent j'aimerais savoir le temps qui c'est passé juste après avoir lancer mon go.... trop tard :) est il possible d'avoir un historique de ce compteur, pour qu'a la fin du show l'on puisse savoir combien de temps à durer chaque scène pratiue en création...
-time groupe : ne serait'il pas avantageux que tout les channels sur la cue active et précédente soit dejà chargé dans la fenêtre? aussi que le double click sur le temps ou delay soit actif avec le petit nuage pense bête...
Bon ce fait beaucoup de "request" j'espère qu'elle ne sont pas trop folklorique ou désuète (vu que je ne suit que de loin les nouvelles béta)
Je ne suis absolument pas conscient du travail que ca représente en programmation toute ces demandes, alors Mr Bats ne m'en voulez pas trop... Puis c'est juste des idées comme ca, pour essayer d'apporter une micro pierre à cet edifice... Encore un grand bravo pour ce soft, un vrais régale à chaque fois...
Shani
11 years 6 months ago #9920 by Wishmapper
Replied by Wishmapper on topic DL4 request
Je suis d'accord avec Jefff !
The following user(s) said Thank You: totoine
11 years 6 months ago #9927 by sl1200mk2
Replied by sl1200mk2 on topic DL4 request
4 line of text:
déjà qu'on a des problèmes de taille d'écran (height) comment vous voulez que je rajoute une ligne?
j'ai mis 3 ligne à cause du GO sur GO.
quand on fait cette manip (enchainer le GO, et en spectacle, c'est le pire des cas... genre ya un souci) le texte de la 3ème ligne et de X2 défilent, donc on sait où on en est.
si je rajoute un e4ème ligne ça se fera forcément au détriment d'autre chose... et je vois pas quoi....
let's talk
11 years 6 months ago #9929 by sl1200mk2
@shani,
la request est trop longue pour que j'y réponde en détail, mais grosso modo, t'as raison sur tout....
teste la beta (entre parenthèse), elle est sympa....
pour le link OSC (ça devrait s'appeler SLink comme ScriptLink) c'est prévu.
faut juste que j'ai le temps de la faire.
pas de fullscreen... c'est comme ça
capito..., mais moi, mon nanoK marche par 9... et en largeur d'écran, ya assez de place pour afficher 10
donc on va laisser comme ça
yep , ça serait bien.
maintenant que DL évolue, et que j'apprends de plus en plus à coder, ça devient faisable.
et se serait super d'avoir l'output dispo sur un deuxième écran.
to be continued...
ça serait possible (tout est possible...) mais DL est pas programmé comme ça.
si tu veux enchainer les spectacles, c'est possible sans fermer le soft et dans une utilisation d'accueil ou genre Avignon, ça doit suffire...
niet.
on revient au moment de la conduite
ya des super jeux d'orgues qui ont un mode 'learn'
du coup il enregistre les temps entre chaque GO et affiche le temps restant avant le prochain GO.
ça, j'aimerai bien le coder.
les TGroup (qui s'appelent TLink dorénavant) ont bien changés dans la version 4 de DL...
et pour répondre à cette dernière question... faudrait qu'on en discute autour d'une bière ;-)
11 years 6 months ago #9930 by totoine
Replied by totoine on topic DL4 request
Bonjour à tous !
Deux petites idées comme ça en passant :
- Pouvoir dans la création d'un chase que les palettes des devices s'enregistrent dans les différents pas de séquences.
- Affection de messages MIDI pour les palettes de devices ? Le problème que ca soulève c'est que pour affecter il faut qu'un(des) circuit(s) de devices soit sélectionné...
11 years 6 months ago #9936 by Jefff
Pour le compteur de temps j'avais pensé à une option du style entre tel n° de cue et un autre, combien de temps s'est-il écoulé. Par exemple entre le Go de début de spectacle et le noir final.
Effectivement pour le Tlink autant avoir tous les channels déjà dedans avec leurs temps et délais par défaut (ceux du cue)
11 years 5 months ago #10048 by Wilf
I thought about some things that I have forgotten, behaviours in 3 and 4:
1. When opening a subwindow like MIDI or Patch the window gets created. When it is at the background and one chooses the window again via the 'Display' menu, the window gets rewritten, i.e. everything that was on (in test for example) gets nulled to default. Is that a feature (a reason behind it) or could that be changed?
2. When flashing via MIDI (with note on with velocity > 0) all other subs are pushed away (zeroed out) until one flashes again with velocity 0. Is that a feature or could that be changed?
11 years 5 months ago #10049 by sl1200mk2
@Wilf,
at some points, I need initialization when opening a window... so this is more like a feature.
can you please elaborate....
do you mean that if you flash a sub and maintain the flash, when you flash another sub the first one is set to zero ?
11 years 5 months ago #10050 by Wilf
sl1200mk2 wrote: @Wilf,
It's like this: suppose I have multiple subs open, be it lights or chases, when I flash another sub with MIDI (which I do from Qlab) then all other subs are set to zero for as long as I send velocity > 0 to the flashed sub. When sending velocity 0 to the flashed sub the other subs go back up.
Time to create page: 0.204 seconds
