4.1.10 dev cycle
6 years 5 months ago #20084 by SoundSurfer
Replied by SoundSurfer on topic 4.1.10 dev cycle
no problem whatsoever on Macbook with Catalina 10.15.4..
6 years 5 months ago #20085 by sl1200mk2
Replied by sl1200mk2 on topic 4.1.10 dev cycle
@soundsurfer
@theFran,
Si, c'est ça ton pb.
tu peux avoir accès au PC?
sinon je peux désactiver la clé à distance mais c'est mieux si c'est clean et si c'est toi qui le fait.
6 years 5 months ago #20086 by thefran
Replied by thefran on topic 4.1.10 dev cycle
@sl1200mk2
Ok merci, je m'en doutais un peu aussi. J'ai accès au PC oui, je vais m'en occuper dans mon coin alors.
Et merci pour ta release pour ubuntu !
6 years 4 months ago #20093 by sl1200mk2
@all,
here's some news...
during these days I've developed a custom Dmx Input Patch which you'll be able to use in order to patch incoming DMX data to Device's colours/Pan/tilt/etc... as well as conventional lighting.
(it was inspired by Florian Leduc work with D::Light and madMapper)
it works pretty well (using sACN protocol)
in the mean time I've made other tests of DMX Input using USB and noticed that DMXKing widgets works very well (even this widget which is very useful to get data from traditional light board dmxking.com/usbdmx/ultradmxmicro ), and the Enttec's one are sending shit...
I'm working to get the incoming DMX works better with artNet and I'll publish a new rc _ as well as video which demonstrate the use of D::Light and madMapper (it's huge... :) )
6 years 4 months ago #20103 by sl1200mk2
la 4.1.10_rc6 est en ligne.
pas mal de modifs/new code (j'aurais pas dû pendant un cycle RC, mais bon...) dont notamment le Patch d'Input.
Je ferais une vidéo Vendredi avec MadMapper pour vous montrer comment ça fonctionne mais en vrai c'est hyper simple.
merci de vos retours.
j'aimerai bien publier la release 4.1.10 à partir de celle là dans 10j
6 years 4 months ago #20104 by sl1200mk2
la video est en ligne...
6 years 4 months ago #20105 by celio
Replied by celio on topic 4.1.10 dev cycle
salut Nico, je voulais essayer avec Isadora plutôt qu'avec Mad mapper. Isadora ne gère que le ARTNET. On peut le faire en local le artnet ou c'est forcément avec un boitier ?
A bientot
Célio
6 years 4 months ago #20106 by sl1200mk2
salut Celio,
tu peux utiliser le même principe en artNet (j'ai essayé et ça fonctionne bien).
t'as pas besoin de boitier, fais en sorte que Isadora streame les paquets artnet vers 127.0.0.1 (en unicast).
Juste un truc qu'il faut que je change c'est le compte des univers d'Input en artNet qui devraient afficher 0, 1, 2 et 3 au lieu de 1, 2, 3 et 4
dis moi comment ça réagit chez toi.
6 years 4 months ago #20107 by celio
salut Nico, avec madmapper oui c'est bon ça marche en artnet
pour l'instant je n'y arrive pas avec Isadora mais ça vient d'isadora je pense le problème.
je continue a chercher.
Au passage, c'est faisable d'avoir ArtNet ou sacn en entrée et dans le meme temps de l'usb dmx en sortie ?
6 years 4 months ago #20108 by sl1200mk2
ouaip, c'est fait pour :)
tu peux même avoir de l'input en usbDMX (genre le flux provient d'une console) et faire de l'output en artNet ou sACN.
dans ce cas de figure j'ai eu des bons résultats avec le ultraDMX Micro de chez DMXKing.com, mais pas avec les boitiers Enttec
6 years 4 months ago - 6 years 4 months ago #20109 by leoclarys
Replied by leoclarys on topic 4.1.10 dev cycle
Je suis en train de tester la RC6 native sur un MBP 2012 13", Catalina, et la fenêtre en mode attached est trop grande pour être affichée en entier. Je te joins une capture d'écran.
Bise!
Last edit: 6 years 4 months ago by leoclarys.
6 years 4 months ago #20113 by anatol
Replied by anatol on topic 4.1.10 dev cycle
testing the rc6 i still can't get out of demo mode or deactivate the key.
as well, while poking around, assigning channels to devices i get this:
"./DLight.sh: line 9: 14998 Segmentation fault (core dumped) $my_path/bin/DLight $1" in stdout.
6 years 4 months ago #20114 by sl1200mk2
@leo,
et si tu augmente la résolution de l'écran? t'es à combien?
@anatol,
I've fixed the segfault (I saw that too late for the rc6....) sorry about that.
regarding your licence key, can you email me [sl1200mk2 gmail] in order to fix that for good.
6 years 4 months ago #20115 by leoclarys
Je suis au max (1280x800)
6 years 4 months ago #20116 by sl1200mk2
4.1.10_rc7 is online
last chance to fix stuff (release will land next week)
Time to create page: 0.285 seconds
