Enttec DMX USB PRO + OSX 10.11 El Capitan
on va pas écrire plus longtemps ici sur la b47 ni la b48, mais tu peux me joindre le sho en question?
thanx,
- Jefff
- Thank you received: 7
- Jefff
yep... fixed
- Jefff
- guillemds
I Capitan Mac software and I can not connect ENTTEC pro.
I disconnected the SIP search does not work ... I have done correctly ... "cmd R to restart, and then uses terminal" csrutil disable "and then restart the computer ... but it does not work!
Can you help me please ??
Thank you very much!
be sure to use this version of DL (you can find it in Download/beta)
- guillemds
When set to Setup DMX Output and select USB DMX with no little connecat ENTTEC pro.
Any solution?
- guillemds
I tried disconnecting the SIP but also detects ENTTEC.
But I've tried other software, such as MadMapper if I detect ENNtec.
Not sure what to do ... well someone ENTTEC the DL with Captan ???
Thank you fellow !!!
- guillemds
My name is Guillem and I DLight user. I've told the forum but I have a problem with my usb pro Enttec.
I downloaded the new version of I-MAC EL CAPITAN. I also have version B48 DL.
The problem is that I can not put the DMX USB mode on.
I see that other programs use as MadMapper if it detects USB DMX Enttec pro with the same computer ...
I can help find a solution ??
- gemasco
- Thank you received: 2
did you try to re-launch X11 ? or even your mac ?
- vafredo
Je suis très emmerdé...je travaille avec DL b51 sur mac avec XQuartz 2.7.8 et je viens de faire une grosse bourde...j'ai installé la MAJ el Capitan et plus rien ne fonctionne. DL ne reconnaît plus le boîtier DMX USB Pro de chez Enttec. Que puis-je faire? j'aimerais une réponse claire et en français si possible....je vous remercie déjà pour votre aide ...
a tout de suite j'espère.
fred
ps: ordi: Macbook pro (Retina, 15-inch, Mid 2015)
une nouvelle version de la b51 pour x10 et x11 est disponible en téléchargement.
getdlight.com/index.php/forum/2-releases...0-b51?start=30#11185
a tester si ça règle le problème.
- vafredo
osascript souhaite effectuer des modifications. Saisissez votre mot de passe pour donner l'autorisation"
J'introduis mon mot de passe mais à chaque tentative de connexion, le même message apparaît...
voilà
- Piero
Je viens d'installer la nouvelle b51, et avec El Capitan + dernière version de XQuartz ça fonctionne. J'arrive à loader mon dernier show, les commandes MIDI suivent etc... Mais toujours pas d'activation du Enttec DMX USB Pro, malgré le fait d'avoir désactiver le SIP via Terminal dans l'interface de boot du Mac...
En est-il de même chez vous ?
Et sinon, une solution peut-être ?
Dans tous les cas courage avec toutes ces mises à jour !
Pierre.
