Enttec DMX USB PRO + OSX 10.11 El Capitan
- nomatter
do NOT update OS X to the next version, El Capitan.
The interface Enttec DMX USB PRO (and
:Light) will not work.Enttec is aware of the problem.
This is the answer of Enttec support to my question:
"Apple doesn't allow disabling the in-built driver anymore, which means you cannot use the D2XX driver that most DMX USB Apps rely on
For now, we will advise not to update, till we have more information on a workaround or a solution
There might be other Apps that support the Apple driver - which will allow DMX USB PRO to work on OS X 10.11"
We'll stay tuned,
bye,
Carlo.
that's interesting...
DL do not use at all D2XX drivers...
but DL attempt to unload from the kernel some AppleFTDIDrivers...
which version of DL did you try?
do you have a preview of El capitan? or is it out?
forums.developer.apple.com/thread/12581
and try these commands from the terminal:
sudo chmod -R 755 /System/Library/ProlificUsbSerial.kext/
sudo kextload /System/Library/ProlificUsbSerial.kext/
and retry to see if USB properly work with DL
thanx,
- nomatter
thanks for the link.
I have a clean installation of last Public Beta of El Capitan. Definitive version will be released this or next week (we'll know on 9th)
I tried with b46 and yesterday I had an attempt also with b47.
For what I understand problem is SIP, System Integrity Protection. Apple doesn't allow Apps to modify system files. Period.
Kernel Extension could be added or edited only by certified or signed developer.
(Apparent) solution is to disable SIP by access to recovery mode (cmd + R) at boot and via Terminal "/usr/bin/csrutil disable"
Then reboot and d::light (and also Enttec Pro-manager) finds the interface.
For a few times.
Yes because, I don't know why, after a while it stop finding it. I've tried a lot, unsuccessfully.
I had to go to Recovery Mode, "clear" SIP, reboot, new recovery mode, disabling it again and the story starts again.
Odd, no?
That's my report.
Ah: ProlificUsbSerial.kext doesn't exist in my system. Even after disabling SIP.
Thanks a lot,
Carlo.
- Morpho
- Thank you received: 1
Did anyone tried the Enttec ethernet DMX bot with 10.11 and Dlight ?
Is the the update possible ?
If not, will it be compatible soon ?
Thanks,
Florian
I need to polish it though...
- Jefff
- Thank you received: 7
Du coup la b48 a l'air bien... :blush:
- nomatter
you can try disabling SIP, the new System Integrity Protection.
Here, in Function section, you can find instructions to do it: en.m.wikipedia.org/wiki/System_Integrity_Protection
Let us know if it works for you.
Carlo.
- balgrim
be aware that it's not a finished beta (because DLink and TLinks for chases are not finished.... but you can have a look into it
it's just to see how things are going:
opening existing sho
setup usb/dmx connection
etc...
thanx for your feedbacks
- balgrim
(Sytem Integrity Protection off)
Soon, will test over SIP on !
- balgrim
I tested QLC+ working with the the Enttec USB dmx Pro.
available soon.
- Jefff
