Mac osx 10.7.2, usb DMX Pro, not working!!
14 years 9 months ago #3780 by blixlab
Hi i have 10.7.2 and a USB dmx Pro, i have tried all releases of D::light and i can not get it to work... the latest beta just shows blank windows and the last stable will not allow me to access the menus or recognize the USB DMX Pro.
Can someone help and please give a basic up to date installation process for 10.7 and USB DMX Pro?
Any help would be greatly appreciated.
Ro
14 years 9 months ago #3783 by sl1200mk2
Replied by sl1200mk2 on topic Re: Mac osx 10.7.2, usb DMX Pro, not working!!
hi,
i've made mistake with the latest beta, i think i'll put an update today.
please be patient and try again when it'll be available.
14 years 9 months ago #3791 by sl1200mk2
u can try with 3.0.7_b10
14 years 9 months ago #3794 by blixlab
Thank you. This seems to work but i am still having an issue connecting the USB DMX Pro. it just says "connecting..."
Pleas which driver must i install?
Thanks
14 years 9 months ago #3795 by sl1200mk2
i don't know why it doesn't work on your computer as this installer work on a Mac 10.7.2 'out of the box'....
you can try to select /dev/usb-serial as modus operandi but in that case, you need to install ftdi driver that you can find here:
www.ftdichip.com/Drivers/VCP.htm
also once you've installed ftdi driver can you please give a try with libusb again just to be sure that it doesn't work in any case on your computer...
i mean, maybe drivers must be installed...
14 years 9 months ago #3796 by sl1200mk2
also, you can give a shot to OLA DMX server as it give access to a wide variety of lighting protocol (including usbPro)
opendmx.net/index.php/OLA
14 years 9 months ago #3803 by blixlab
Hi I have tried these and still no luck, i have installed OLA, D2XX1 and VCP, the device is running fine in the enttec pro utility but will not connect in D::light! If you have any ideas as i am a little desperate at this stage...
14 years 9 months ago #3804 by sl1200mk2
did you try with another usb port?
can you try some command in a terminal (/Applications/utility/terminal) as described here
staton.us/electronics/python/OSX_FTDI_USB.html
here's the result from my terminal
brouhaha:daylight nico$ sudo kextstat | grep FTDI
145 0 0xffffff7f808b5000 0x8000 0x8000 com.FTDI.driver.FTDIUSBSerialDriver (2.2.16) <99 30 5 4 3 1>
can you post yours?
it's a shame because as i told you with a 'virgin' mac, i succeded to establish connection...
14 years 9 months ago #3805 by blixlab
Terminal gives me this:
127 0 0xffffff7f8079b000 0x8000 0x8000 com.FTDI.driver.FTDIUSBSerialDriver (2.2.16) <104 31 5 4 3 1>
14 years 9 months ago #3806 by sl1200mk2
so, did you try to select /dev/usb-serial as modus operandi ? (and don't forget to click on the red led to activate things)
14 years 9 months ago #3807 by blixlab
Yes i have tried both modus operandi and when i click the red light i just get a message saying "connecting..." but it never connects! I have also tried with a saved .sho file and a new file. i have restarted many times and also repaired permissions.
14 years 9 months ago #3808 by sl1200mk2
can you manually unload ftdi drivers, and try to connect usbPro via libusb.
the command is
sudo kextunload /System/Library/Extensions/FTDIUSBSerialDriver.kext
14 years 9 months ago #3809 by blixlab
OK i did this, no change
14 years 9 months ago #3810 by blixlab
should i also uninstall the D2XX driver?
14 years 9 months ago #3811 by sl1200mk2
don't know, i've never used them..., but if you can, go ahead.
here's what you gonna try:
be sure to have unload ftdi driver.
the attached zip is only the executable (modified of course, it will assume there's no ftdi driver)
Ctrl+Click on DLight icon, select show package contents (i don't exactly know in english), move to contents/Resources and put dezipped joined files in it
launch DL, create a new show and try to connect to usbPro via libusb.
my goal is to test if the applescript to unload ftdi drivers is faulty. as this executable assume there's no need to unload drivers
Time to create page: 0.189 seconds
