4.1.07 dev cycle
6 years 4 months ago #19450 by sl1200mk2
Replied by sl1200mk2 on topic 4.1.07 dev cycle
@Benji
fixed pour la prochaine beta
@leo
Chez moi le "open recent" ne propose plus rien.
6 years 4 months ago #19455 by dFVarela
Replied by dFVarela on topic 4.1.07 dev cycle
@Daniel,
Hi,
here it works fine on win10.
would you mind trying to uninstall previous version first? or at least be sure that the instal won't pick up an existing dlight's directory
It works fine... On the first computer i've made the test i can't install so i've made an extract of the installer!
The submaster pages are now of 10 or of 16 submasters?
I can resize the pad windows but when resizing sideways the sequence windows always get a white space!
dFVarela
dFVarela
6 years 4 months ago #19456 by sl1200mk2
@Daniel,
thanks for your feedback,
in the SetUp there's a new attached/detached option for the UI
attached = 10 subs
detached = 16 subs
yes, I didn't managed yet to get the whole window to resize...
6 years 4 months ago #19457 by sl1200mk2
@leo,
tu verras pour la prochaine beta dans le DC quand tu clique sur le n° du circuit, ça sélectionne toute la ligne.
c'est pas mal je trouve....
donc pour la feature de copy je te propose de rajouter dans le bandeau du haut un icone de Clone, et la syntaxe serait:
all [xx] Clone (et en @mode: All CloneFrom xx) où xx est le n° du circuit à partir du quel on veut cloner.
le clone ne fonctionnerait que pour la page d'attributs affichée
your thought?
6 years 4 months ago - 6 years 4 months ago #19458 by dFVarela
Hi,
When detaching whit dynamic bottom opened get the following error:
invalid command name ".dynBottom4Device.sa.tbl.body.frm_k4,2.w.g.c.c"
while executing
"$coarse itemconfigure $localxElt(coarse,$def,$channel) -text $locCoarse"
(procedure "coroIzeduniDeviceLiveDispatch" line 67)
invoked from within
"coroIzeduniDeviceLiveDispatch DynamicBottomLive 5 {GREEN {0 0 HOME4Devices 0 {}}}"
("after" script)
dFVarela
Last edit: 6 years 4 months ago by dFVarela.
6 years 4 months ago #19459 by sl1200mk2
@Daniel,
yes, I think I've fixed it already.
I'll push b2 with the fix in few minutes... :)
6 years 4 months ago #19460 by sl1200mk2
@everybody
b2 is online :)
merci de vos retours.
@Daniel,
I've also pushed the raspberryPi4 version. would you mind trying it?
6 years 4 months ago - 6 years 4 months ago #19461 by dFVarela
@Nico
Saw your message late... Going to Brest tomorrow, so didn't had much time! It seems to be working ok on RPI4, just downloaded it and made a new show....
dFVarela
6 years 4 months ago #19466 by KoniArt
Replied by KoniArt on topic 4.1.07 dev cycle
Sur la Beta plus de Bug pour les chases !!!
Bravo
Petit truc moi je préférais quand tout le sub avais la couleur que l on sélectionais.
Belle journée
6 years 4 months ago #19468 by sl1200mk2
@koniArt,
j'ai regardé ton sho gameOver et j'ai vu que t'utilisais pas mal de Leds à 3 offsets.
dans le device listing, je te conseille de cocher 'virtual Intensity for colours' si tu veux profiter du MoveInBlack...
mais ça m'a fait bosser justement sur le paramètre d'intensité des Leds quand il est controlé depuis le dynamicBottom ou depuis le deviceCommand et je me suis rendu compte qu'il y avait là aussi un pb...
du coup j'ai corrigé et je vais publier une b3 avec ce fix.
pourras-tu essayer ce cas bien précis, stp?
6 years 4 months ago #19469 by sl1200mk2
la b3 est en ligne.
The following user(s) said Thank You: KoniArt
6 years 4 months ago #19475 by jerry0301
Replied by jerry0301 on topic 4.1.07 dev cycle
Petit soucis suite à la mise à jour passant le nom des affectations midi de "sub page +" à subpagenext. Lorsque j'exporte mon mapping midi avec ces paramètres attribués (subpagenext et subpageprev) je me retrouve lorsque je reimporte, avec les anciens noms (subpage + et -) et du coup mes touches ne marche plus je suis obligé de réattribuer !!
Merci d'avance
Jérémy
6 years 4 months ago #19480 by KoniArt
Yes merci je suis partie je suis plus sur Game Over mais la prochaine fois je teste ça.
Belle journée.
6 years 4 months ago #19487 by celio
Replied by celio on topic 4.1.07 dev cycle
salut Nico,
Crois tu qu'il serait possible que la fonction anchor masterlink to séquence (step +et -)puisse aussi déclencher les Step link ?
Merci bien. J'espère que le Bis à Nantes ça c'est bien passé.
Bonne journée
Célio
6 years 4 months ago #19489 by sl1200mk2
@Celio,
hello, ouaip le BIS c'était bien, ya eu quelques personnes qui sont venues sur le stand, des curieux, des user(e)s qui avaient un souci sur leur sho, des boites de prod intéressées par le système.
Même un mec en costardCrav qui avaient entendu parlé de DL en conférence mais qui à mon avis avait confondu avec une société qui s'appelle Delight... :)
pas avec la fonction 'anchorMLink' mais je peux en rajouter une nouvelle genre 'anchorStepLink'
Time to create page: 0.209 seconds
