3.0.8_b1
14 years 7 months ago #4281 by colinc
Replied by colinc on topic Re: 3.0.8_b1
Salut Nico
sl1200mk2 wrote: @Colin
while working on @Mode for editors, i'm wondering if existing syntax are good?
for example, does [CUE] XX [LOAD] shouldn't be [LOAD] [CUE] x.xx ?
another example:
does [GROUP] XX [REC] shouldn't be [REC] [GROUP] x.xx
or [STEP] XX [INSERT] -> [INSERT] [STEP] XX
Yes, [RECORD], [LOAD], [INSERT], and similar commands (eg a [DELETE] command) should come first I think - almost a 'standard' syntax now - Strand, ETC, Zero88, others, all use that form. As I've said before, people coming new to DL will find it easier to make the move...
sl1200mk2 wrote: any thoughts?
Regards
14 years 7 months ago #4283 by dFVarela
Replied by dFVarela on topic Re: 3.0.8_b1
There is a long time I don't work with a Strand board but from what I recall it depends if you're working with command line or direct input is used!
CUE XX.X REC and CUE XX.X LOAD is correct for direct input, but whe on commadand line it should be REC CUE XX.X
dFVarela
14 years 7 months ago #4285 by sl1200mk2
Replied by sl1200mk2 on topic Re: 3.0.8_b1
it's a shame that nobody have noticed that before....
14 years 7 months ago #4286 by colinc
dfvarela wrote: There is a long time I don't work with a Strand board but from what I recall it depends if you're working with command line or direct input is used!
I think that may have been 'old' (DOS based) Strand - new Phillips/Genlyte Palette OS gives it the other way round - ie for command line it's [CUE] XX [RECORD] (pp 171/172 of the manual)
Regards,
14 years 7 months ago #4287 by sl1200mk2
[CUE] XX [RECORD] is in the middle way between RPN and @Mode, and as i'm not (till yet) an @Mode guy, it confused me at initial steps.
now i'm re-writing things to accept [RECORD] [CUE] xx
wich is a less powerfull syntax (i think) but closer to spoken words
Nico
14 years 7 months ago #4288 by sl1200mk2
what about this one:
[CH] XX [INV] or [INV] [CH] XX
the purpose of [INV] is to select channel with a level and deselect those under selection.
this command should select all channels with a level, except channel XX
wich form is suiting well ?
14 years 7 months ago #4293 by colinc
sl1200mk2 wrote: what about this one:
I think in this case, the [CH] XX [INV] is better - or even just XX [INV] (kind of like an upside-down 'REM DIM ' command (which would be: XX [REM DIM])
Regards,
14 years 6 months ago #4303 by pipou
Replied by pipou on topic Re: 3.0.8_b1
Salut!
J'ai trouvé un bug, je ne sais pas s'il a déjà été relevé, donc je t'en fais part :
Sous windows 7 32b ET 64b
cela concerne la fermeture de connexion entre dlight et l'usb dmx pro :
je lance un .sho, usb/dmx activé au lancement ou après dans le setup. Tout marche bien.
si je n'éteinds pas la connexion dmx via la LED verte avant de charger un nouveau show, la connexion se perd, dlight affiche en haut à droite un truc du genre libusb failed, no usb dmx pro found. Impossible de reconnecter sans avoir redémarré le soft. Pourtant, en chargeant un nouvelle conduite, dlight affiche bien qu'il ferme la connexion avant le chargement...donc il la ferme mal. A noter que si je ferme moi-même avant de charger la conduite, le problème ne se pose pas.
pipou
14 years 6 months ago #4304 by sl1200mk2
@pipou
thanx dude, je vais vérifier ça!
elle a intérêt a te plaire la beta 2 avec tous les retours que t'as fait ;-)
en ce moment je suis toujours sur l'@Mode, j'ai fini les éditeurs des Cue/Group/Sub et bientôt fini les FX.
après, je regarde tes bugs, j'essaye d'améliorer l'artnet et la détection d'interface sur iphone/android (pour autant qu'elles utilisent Control). un peu d'ascii...
*j'essaye* de mettre en place le mapping de l'OSC writer et je publie tout ça
j'aimerai bien y arriver pour la mi-Avril
14 years 6 months ago #4316 by sl1200mk2
@Mode
for the patch window, are you ok with
[CH] xx [@] yy
to patch dimmer yy to channel xx ?
i like it, because it's fast, you don't have to learn one more shortcut and it's close enough to spoken words.
i think i'll try also to do
[CH] xx [@] yy [THRU] zz
to patch dimmer from yy to zz to channel xx
14 years 6 months ago - 14 years 6 months ago #4318 by flk
Replied by flk on topic Re: 3.0.8_b1
Here I chime in :)...
Once again, in terms what is out there (at least ETC)- funnily enough:
([DIM]) YY ([AND, THRU, NOT] [DIM] ZZ) ENTER ([CH]) XX ENTER
- which makes sense, as you are selecting several Dimmer channels first, to assign them then to a Channel once you are done...
Examples become quite quick that way, like thus:
"1 ENTER 6 ENTER" patches dimmer 1 to Channel 6
"2 THRU 7 NOT 5 AND 10 ENTER 20 ENTER" patches Dimmers 2,3,4,6,7,10 to Channel 20
does thak make sense?
Last edit: 14 years 6 months ago by flk. Reason: Made a mistake
14 years 6 months ago #4319 by flk
oh, and the @ is used for proportional patching, meaning if you go
([DIM] YY @ ZZ ENTER ([CH]) XX ENTER, that will be interpreted as when you bring CH XX to 100%, that DIM YY will only shine at ZZ % of its full intensity (and obviously in proportion when you take the Intensity of CH XX to i.e. 40, the formula would be 40* (ZZ/100).
14 years 6 months ago #4320 by sl1200mk2
@Freddy,
glad you chime in here ;)
we don't need to forget that DL must accept both RPN and @Mode notation and so we must deal with what have been done for RPN...
i mean that i agree with you that [AND] and [NOT] can be added to the patch window but in terms of compatibility with RPN and graphical window's design it's a no go.
moreover, generally, on tour, when i patch everything there's someone close to me that tells me:
"1 - 100, 2-34, 3-35 et 36" where first number is [CH] and last one are [DIMMER].
i don't quite often use the [THRU] function except to patch house lights and to set curve for all dimmers.
so i don't think i'll add [NOT] and [AND] functions to patch for this release.
it can be done for the future but i need to change patch window's design to make it looks like all the other editors. and something is still prevent me to do that is that with patch as list i have a quick overview of what is patched and which dimmers are free....
so at this point we still have several solutions:
[CH] xx [@] yy [ENTER] or [CH] xx [DIMMER] yy [ENTER]
i'm still happy with the first solution because in DL you can patch in channel->dimmer way or dimmer->channel way, and thus for the second case i think that [DIMMER] xx [@] yy [ENTER] will fit well to patch dimmer xx to channel yy.
more commands will be allowed
[CH] xx [@] yy [THRU] zz [ENTER] to patch dimmers from yy to zz to channel xx
[DIMMER] yy [THRU] zz [@] xx [ENTER] (available in dimmer->channel way) for the same purpose
of course in the channel->dimmer way single number will be prepending by [CH] if you not type it, and in dimmer->channel way, single number will be prepending by [DIMMER]
of course as you've noticed the use of [@] prevent his use to set dimmer level but as it's not an available feature in DL it's ok for now.
any thoughts?
best,
14 years 6 months ago #4324 by flk
How funny - when on tour, I usually get the opposite, people saying:
"100 into 1, 34 into 2,...", which is probably also due to the culture of widely using ETC Jargon. hmm...
not too fussed about not having "AND" and "NOT straight away, but am I understanding you correct that you just want to _add_ @mode syntax _on top of_ RPN? As opposed to having the switch in Setup to use only RPN or only @mode? To me, the second option would make more sense, if you are an @mode kinda guy, you'll want to use it through the whole program, similarly if you are RPN and want to stay that way, that probably goes for the whole program, am I right?
In which case you wouldn't need to pay too much attention what's going on on the "other" side? I am just saying, what's the benefit of introducing the option and then not go all the way to make it familiar to the @mode people :)?
In having said that, I do understand that there are program limitations, and proportional patching is certainly not a priority...
Thinking though, I use "THRU" mainly to unpatch portions of a 1-to-1 patch, so granted, not necessarily relevant or important.
The "NOT" is not really that important, agreed.
The "AND" I do use quite often when patching, I often put the intensity of a set of LED ParCans on one channel i.e., but again, not a priority.
What would be important to me (as an @mode user :)), is that I would need to enter the least possible to achieve what I am used to (and if that needs to include the @ command, then be it...
sooo.... could it be, that when the program is switched to @mode, the patch would understand when I say
"20 @ 2 ENTER"
that I mean DIMMER 20 to be patched into channel 2?
That would make me happy :)... but of course, it's not all about making me happy here ;P
a+
Freddy
14 years 6 months ago #4326 by vbs
Replied by vbs on topic Re: 3.0.8_b1
Hello
i tend to agree with Freddi about pachting dimmers to channel.
That is realy what happens if you visithing a veneu.
Some desk like Compulite with is used a lot in the Netherland is standard dimmers to channels (but there you can change this as well)
More dimmers to a channel would than be 12+16+45@10 enter
Dimmer 12,16,45 on channel 10
This would also make my happy
Thanks Vincent
Time to create page: 0.238 seconds
