3.0.8_b1
14 years 8 months ago #4109 by sl1200mk2
Replied by sl1200mk2 on topic Re: 3.0.8_b1
@ouaiouai,
je viens d'essayer sur Win7, et tout est passé nickel...
en plus ton fichier est des plus simple et je ne vois pas du tout où il a pu faire bugger DL...
aurais-tu quelques infos supplémentaires sur le crash qui arrive?
d'autres personnes faisant tourner DL sur win7 pourraient-ils essayer un import ascii avec le fichier joint?
14 years 8 months ago #4110 by colinc
Replied by colinc on topic Re: 3.0.8_b1
sl1200mk2 wrote: @ouaiouai,
Hello Nico,
Not Win 7, but under Win Vista HP, the import works, but there are significant problems. The Subs load with their groups, but applying a Sub does not affect the main output window. Also the empty Subs on the fist page appear to fill with the last Sub number - but not really
I took a video screen capture of the whole process to show you, but I think it is too big to upload - if you let me know how, I will upload it
Best,
14 years 8 months ago #4112 by sl1200mk2
@Colin,
thanx for the time you involve in this project :)
as you noticed, sub are filled but partially, the reason is that DL need two pass to fill the subs (for obscurs reason, sometimes, they're declared before their contents, etc...) and i did that for ascii files that come from EOS family, but i forgot to do the same for ascii files coming from others lightboard.
as on the presto it's possible to load 'contents' (i mean not groups, neither cues), these 'contents are recorded on DL as Groups - this is the way DL works - that's why they're recorded after the last groups.
i'll fix that for the next beta,
thank you for pointing that.
14 years 8 months ago #4115 by ouaiouai
Replied by ouaiouai on topic Re: 3.0.8_b1
Je te poste le rapport de clsh:
Nom d’événement de problème: APPCRASH
Nom de l’application: DLight.exe
Version de l’application: 0.0.0.0
Horodatage de l’application: 4f3378e7
Nom du module par défaut: DLight.exe
Version du module par défaut: 0.0.0.0
Horodateur du module par défaut: 4f3378e7
Code de l’exception: c0000005
Décalage de l’exception: 00129243
Version du système: 6.1.7601.2.1.0.256.48
Identificateur de paramètres régionaux: 1036
Information supplémentaire n° 1: 0a9e
Information supplémentaire n° 2: 0a9e372d3b4ad19135b953a78882e789
Information supplémentaire n° 3: 0a9e
Information supplémentaire n° 4: 0a9e372d3b4ad19135b953a78882e789
Lire notre déclaration de confidentialité en ligne :
go.microsoft.com/fwlink/?linkid=104288&clcid=0x040c
Si la déclaration de confidentialité en ligne n’est pas disponible, lisez la version hors connexion :
C:\Windows\system32\fr-FR\erofflps.txt
14 years 8 months ago #4116 by ouaiouai
Je viens d'essayer avec d'autres conduites qui proviennent de congo, presto etc.
DL crashe de la même façon...
En revanche dans mon xp, tout se passe bien.
14 years 8 months ago #4128 by pieri
Replied by pieri on topic Re: 3.0.8_b1
Bonjour à tous !
Premier essai avec cette nouvelle Beta ! Les fichiers s'ouvrent sans problème que ce soit .Sho, et ASCII...
Je n' ai pas trop le temps mais je teste au plus vite avec le boitier ENTTEC, la nano kontrlol2, et l' OSC très vite !
Je tourne avec Win.Vista, Home Prem.
A bientôt !
14 years 8 months ago - 14 years 8 months ago #4130 by passa
Replied by passa on topic Re: 3.0.8_b1
bonsoir,
testé l'import ascii de la conduite paindur.asc sous windows7 x64, je n'ai pas eu le moindre probleme.
j'ai également testé des imports venant de congos, presto, safari et j'en passe sans probleme.
Last edit: 14 years 8 months ago by passa.
14 years 7 months ago #4134 by sl1200mk2
@tous,
c'est ça qui fait chier sur win, c'est que chez moi comme chez d'autres, les imports fonctionnent, et chez ouaiouai, ça crashe...
bon en ce moment, je suis en train de faire des saignées dans des murs, tirer des cables et tout ça donc j'ai pas trop le temps pour DL, mais j'ai bon espoir d'arriver à publier une deuxième beta avant la fin mars - genre pour le printemps ;-) .
14 years 7 months ago #4147 by flk
Replied by flk on topic Re: 3.0.8_b1
Hm, strange thing - fresh install of MacOSX 10.7.2 on my
Model Name: MacBook Pro
Model Identifier: MacBookPro8,2
Processor Name: Intel Core i7
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 8 GB
Boot ROM Version: MBP81.0047.B24
SMC Version (system): 1.69f3
, installed XCode afresh, logged in and out... but when trying to start DLight, the XCode icon just jumps up and down and I have to force quit after a while :/.
Ideas?
14 years 7 months ago #4148 by flk
Hey Freddy,
it's Freddy :)... What I'm trying to say - I don't know what it was, but after the fresh XQuartz update, it seems to work again... strange! Now into some more testing.
Cheers,
Freddy
14 years 7 months ago #4149 by flk
Hi Nico,
Just wanted to say, I loooove the @Mode! Brilliant :)! However, I did come across our "old friend", an error that I have described earlier:
CH 1 THRU 59 AT 50 ENTER - ça marche. All channels 1 THRU 59 are now at 50%.
CH 1 THRU n AT 50 ENTER (where n > 59) - ça ne marche pas: channels 1 THRU (n-1) are now at 50%.
Mais dehors de ça - fantastique!!! :)
Freddy
14 years 7 months ago #4176 by sl1200mk2
Freddy,
work is not finished regrading @Mode but it's in a good way. I've finished it for the cue editor and it should be fast enough to get it for the others editors ;-)
regarding xcode and xquartz, xcode install things that xquartz doesn't like and fresh xquartz install fix it.
a long standing one...
thanx
14 years 7 months ago #4179 by Wishmapper
Replied by Wishmapper on topic Re: 3.0.8_b1
Comme tu me l'as demandé, je reposte ici.
Je suis en train de paramétrer DL pour une future création, et j'ai un souci d'affichage du texte. Je m'explique : le texte semble être blanc sur fond blanc.
Cela se produit :
- dans les infos-bulles
- dans les cases d'affectations MIDI
- dans les case pour nommer les SUB
Je n'ai pas constaté d'autres emplacements avec le même souci, mais je n'avance pas vraiment avec ce problème plutôt gênant !
J'ai testé avec d'autres "thèmes d'affichage" mais rien à faire...
Config : Win7/BCF2000/Entec (tout fonctionne à merveille, sauf cet affichage !!)
Merci !
14 years 7 months ago #4186 by flk
Allo Nico :)...
I had an idea - what about adding an OSC out -
one that simply writes the string that you currently see between the circuit display and the subs (where it shows the full phrase of what one is trying to type, i.e.
"[REC] 1 [ENTER]" or "[CH] 3 [THRU] 9 [AT] 50 [ENTER]"
... that could be an interesting thing to display via i.e. TouchOSC on an iPad... I am currently working on some awesome templates for DL, using OSCulator and TouchOSC...
Obviously, what would help immensely, too, would be the OSC in's I talked about a time ago (at the time as MIDI, but OSC might be easier for you, and kinda neat anyway):
REC
DEL
CH
CUE
the numbers 0-9
AT
AND
NOT
THRU
RELEASE (Backspace)
Time in
Time out
If those were implemented, you could have a really good remote support to make a fully functional iPad remote for DLight - I'd be happy to develop this and share it here for free, of course :)...
One more thing - when one uses setup to display levels as 0-100% (rather than 0-255), it would be more intuitive if the OSC output and input would also change to 0-100 - currently, it still sends and expects 0-255.
Qu'est-ce que tu pense? :)
Amicalement,
Freddy
14 years 7 months ago #4189 by sl1200mk2
Freddy,
as remote control, i'm working with Control and i began to make a pad for it (called dlPad.js)
into it, bi-directionnal talk is ever coded. not for @Mode yet, of course, but in RPN fashion, what you type is what you got (WYTIWIG ;-) ) on the remote controller.
i'm planning to add @Mode sentence available.
if you want to work with that and touchosc,the message type is /pad/saisieText
with following sended string:
'warning' : error message
'unwarn' : end of error message
'null' : when writing box is cleared
and of course the value as an integer
also, with @Mode pattern, i plan to add all the command you'listed even if some are available yet - the ones of the pad...
one question, does AND is '+' and NOT is '-' ?
and you're right about 0-100%, i'll see what i can do, but that might break existing code of third party...
The following user(s) said Thank You: flk
Time to create page: 0.217 seconds
