- Thank you received: 1075
x-fader 16bit resolution in OSC
Hi,
4.1.05_b2 is online for windows.
would you mind testing the /pad/scaleOne message with +1/-1 value
keep in mind it's not a range... DL will increment each time it receives 1 and decrement each time it receives -1
tell me if it's ok (or not
4.1.05_b2 Native est dispo au download.
idem, peux-tu me dire si la commande /pad/scaleOne fonctionne pour toi
I would like to release tomorrow (according to your feedback of course...)
- stebian
Looking all somewhat new! Was curious to find out about things. I don't have much time the next few days but these are a few bugs I just found:
In Setup I tried setting the number ob Subbook which caused DL to crash.
Also klicking at the slide button above a submaster (the one that shows further options when slid down) in main window made it crash.
Thank you, Nico!
stephan
cool,/pad/scaleOne 1/-1 works fine here.
thank you for your tests
hmmm, I thought I've fixed this one but apparently no...In Setup I tried setting the number ob Subbook which caused DL to crash.
will re-check
ok, will check that tooAlso klicking at the slide button above a submaster (the one that shows further options when slid down) in main window made it crash.
thank you for your quick feedback
does it crash with b2 or with 4.1.04?
- stebian
I can check back later on 4.1.04.
stephan
- stebian
stephan
I've uploaded 4.1.05_b3 for windows
would you mind checking our today's concern?
- stebian
for current b3:
slide buttons still don't work but DL doesn't crash. The one that switches pad/device is still greyed out and does not do anything.
stephan
4.1.05_rc1 is online.
about the slide buttons, I think your issue is that they are not 'sliders' anymore. Now you need to doubleClic on them in order to switch the view.
tell me if it's all fine.
- stebian
Ok, that makes sense. Works all fine! :laugh:about the slide buttons, I think your issue is that they are not 'sliders' anymore. Now you need to doubleClic on them in order to switch the view.
I´m working on the second part of the controller whenever there is time...
stephan
HI,
would you mind testing the 4.1.09_b3 with your system?
I've changed submasters/channels anchor and I would like to know how it behave.
thanks,
- stebian
sorry for my late response. I didn`t notice any exeptional behaviour. All working fine. What did you change?
stephan
stephan
right in time...
I've change the way DL internaly process external levels request... and I'm glad with this new code
