x-fader 16bit resolution in OSC
6 years 10 months ago #19289 by celio
Replied by celio on topic x-fader 16bit resolution in OSC
same problem here with range from -32768 to 32767
6 years 10 months ago #19290 by sl1200mk2
Replied by sl1200mk2 on topic x-fader 16bit resolution in OSC
@cello
Can you post a video or a link to a video to show me your setup and how do you use the freescale command?
6 years 10 months ago #19291 by celio
Yes i could (Not now caus i have to take a train) but just to Know what is the change you made on the new version ?
6 years 10 months ago #19292 by celio
I think I understand something (reading all the topics)
if I'm right, know Freescale is relatif and if I send a value > it's +1 and if I send a value< it's -1
but if I send 100(for ex) it's working after I send 101 (for ex) it's working too because it's > but the problem is when I want to send 101 many times so for dlight it's not > but equal...
That's correct or I'm totally out :))))
6 years 10 months ago #19293 by sl1200mk2
DL should be compatible with software that can send -100 then 666 in 2 messages... and this is incompatible with -1/+1 range
6 years 10 months ago #19294 by sl1200mk2
@celio
das ist correct
6 years 10 months ago #19295 by celio
doesnot matter the value I send.
if the value is not > or < at the previous one, no one si moving. I can't send many times the same value to increment or decrement.
6 years 10 months ago #19296 by celio
so I dont really see the way to use the new versions because I can't have a +1 or a -1 many times.
6 years 10 months ago #19297 by sl1200mk2
with a range of -37000 / +37000 each time you move the fader it should send +1 or +100 depends of the speed of your scroll and the way you move it.
thus, DL will increment / decrement accordingly
6 years 10 months ago #19298 by celio
yes but touch osc don't work like this. With encoder it's value mini when you turn on left and value max when you turn on right....
ok i have to look how to do with the new thing...
for information I have this controller
www.thomann.de/fr/behringer_cmd_dv_1.htm
It's 59 euros and with a Isadora patch you have many control of device....
it's work very well if people are interested...
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
6 years 10 months ago #19299 by sl1200mk2
@Celio,
so maybe we need a new command for touchOSC compatibility that handle +1/-1
lets' find a new name :)
6 years 10 months ago #19300 by sl1200mk2
/pad/scaleOne
6 years 10 months ago #19301 by stebian
Replied by stebian on topic x-fader 16bit resolution in OSC
Ok, I got it now. It works if I keep track of the value within the controller rather then setting it back to zero each time the value has been send.
I'm fine with that. But celio probably can't do that in touchOSC. What is your gain in not wanting to use +/-value anymore? Just being curious...
stephan
6 years 10 months ago #19302 by sl1200mk2
@stebian,
for internal stuff...
I've coded /pad/scaleOne 1 and /pad/scaleOne -1
which platform do you use?
6 years 10 months ago #19303 by stebian
I'm on Windows 10.
Thank you, Nico!
stephan
Time to create page: 0.198 seconds
