x-fader 16bit resolution in OSC
6 years 11 months ago #19094 by stebian
x-fader 16bit resolution in OSC was created by stebian
Hi Nicolas,
since your software allows controlling 16bit LED's and I almost exclusively use the OSC x-faders to move from one cue to another, it would be useful to have the same resolution here. Do you see a way in implementing that?
stephan
6 years 11 months ago #19095 by sl1200mk2
Replied by sl1200mk2 on topic x-fader 16bit resolution in OSC
Hi Stebian,
it could be possible but not in a near future...
another thing, as you use OSC to control stuff, are you aware of the two first commands listed here:
getdlight.com/wiki/index.php/OSC#Syntaxe...n_4_.5B2018-02-01.5D
did you tried them?
another OSC command that I've forget to document anywhere is :
/deviceParameter/COLOUR/RED [0.0...1.0]
it works for selected devices.
in the setupI/O you can choose if /deviceParameter act as relative or absolute mode.
absolute == [0.0...1.0]
relative == -1/+1
as for 4.1.04_b10 absolute works fine, relative never do the -1... I'll fix that
and for the next beta/release, I've reworked /pad/freescale to accept float or int arguments. This message is designed to increment or decrement levels of selected channels (and so INTENSITY/DIMMER for devices)
6 years 11 months ago #19097 by stebian
Replied by stebian on topic x-fader 16bit resolution in OSC
That's fine. I'll go with fade times in cases of annoying visible blinking for now.
And yes, I know these commands. I still need to integrate them in the device wheels on the controller…
I use another wheel which makes use of /pad/freescale, so I will be happy about float arguments on that one.
Thank you, Nicolas!
stephan
6 years 11 months ago #19112 by stebian
Hi Nicolas,
did you change /pad/freescale in 4.1.04_rc1?
I doesn't work here. I was curious to check on sending floats but that did't do either. I tried /pad/freescale +0,1/-0.1
stephan
6 years 11 months ago #19114 by sl1200mk2
HI,
yep I did change it but apparently not in a good way... :)
range for float is 0.0....1.0
next week I'm on tour, I'll be able to double check on Friday...
6 years 11 months ago #19115 by stebian
Oh, I see…:)
When you say range for float is 0.0....1.0, do you mean absolute or relative? Can I even send /pad/freescale 0.01/-0.01 as it works for devices?
Have a good tour!
stephan
6 years 11 months ago #19137 by sl1200mk2
Hi,
the proposal for /pad/freescale is :
whatever value you receive you store it
-if next value is >, increment selected channels
-if next value is <, decrement selected channels
so there's no range...
tell me if it's acceptable for you?
6 years 11 months ago #19148 by stebian
Oh, it totally is!
stephan
6 years 10 months ago #19246 by stebian
Hi Nico,
thanks for the release.
pad/freescale works neither for ints nor floats. It did for a moment on absolute floats only and then it stopped.
stephan
6 years 10 months ago #19280 by sl1200mk2
Hi Stebian,
testing the /pad/freescale here with pureData and it's fine.... so there's must be something somewhere...
pureData is sending message like that:
/pad/freescale f 100 (100 is for example)
on the first time DL is receiving freescale it visually does nothing as the first value is used to set the zeroPoint.
next call by pureData is :
/pad/freescale f 101
DL now knows it should increment so selected channels are processed +1 (not +1%, but +1 in realValue).
where does it fails for you?
6 years 10 months ago #19284 by celio
Replied by celio on topic x-fader 16bit resolution in OSC
Hi Nico, I try with English...
My setup on Touch osc is an Encoder with message /pad/freescale and value range from -1 to 1
All works fine with previous version.
Maybe on the new version i need to update the value range.
6 years 10 months ago #19285 by celio
and I have the same setup on Isadora.
Isadora receive midi from controlleur and send to dlight : /pad/freescale with range from -1 to 1
6 years 10 months ago #19286 by sl1200mk2
Can you try with a range from -32768 to 32767
For several reasons I would like to avoid the former-1/+1 range
6 years 10 months ago #19287 by stebian
Ah, I didn't know I was supposed to send an f for floats... Do i need a preceding i for integers as well? Will try again. Thanks Nico!
@celio
You probably have the same issue as me then...
stephan
6 years 10 months ago #19288 by sl1200mk2
@Stebian,
Are you using pureData?
The f or i is needed when using the sendtyped message to packOSC
Time to create page: 0.194 seconds
