X-Touch (complète) et D::light
- get974
- Nouveau membre
il y a 6 ans 11 mois #14752
par get974
Réponse de get974 sur le sujet X-Touch (complète) et D::light
Quand je monte mon fader 1 à 100%, j'ai ceci comme info sur midiMonitor:
09:57:52.704 From INT Control 1 Controller 15 0
09:57:52.704 From INT Control 1 Controller 47 64
09:57:52.704 From INT Control 1 Bank Select 0
09:57:52.704 From INT Control 1 Bank Select (fine) 0
09:57:52.764 From INT Control 1 Bank Select 2
09:57:52.764 From INT Control 1 Bank Select (fine) 8
09:57:52.784 From INT Control 1 Bank Select 3
09:57:52.784 From INT Control 1 Bank Select (fine) 80
09:57:52.804 From INT Control 1 Bank Select 5
09:57:52.804 From INT Control 1 Bank Select (fine) 92
09:57:52.824 From INT Control 1 Bank Select 8
09:57:52.824 From INT Control 1 Bank Select (fine) 56
09:57:52.844 From INT Control 1 Bank Select 11
09:57:52.844 From INT Control 1 Bank Select (fine) 76
09:57:52.864 From INT Control 1 Bank Select 14
09:57:52.864 From INT Control 1 Bank Select (fine) 124
09:57:52.884 From INT Control 1 Bank Select 18
09:57:52.884 From INT Control 1 Bank Select (fine) 112
09:57:52.904 From INT Control 1 Bank Select 23
09:57:52.904 From INT Control 1 Bank Select (fine) 56
09:57:52.924 From INT Control 1 Bank Select 28
09:57:52.924 From INT Control 1 Bank Select (fine) 0
09:57:52.944 From INT Control 1 Bank Select 33
09:57:52.944 From INT Control 1 Bank Select (fine) 8
09:57:52.964 From INT Control 1 Bank Select 38
09:57:52.964 From INT Control 1 Bank Select (fine) 36
09:57:52.984 From INT Control 1 Bank Select 43
09:57:52.984 From INT Control 1 Bank Select (fine) 80
09:57:53.004 From INT Control 1 Bank Select 49
09:57:53.004 From INT Control 1 Bank Select (fine) 28
09:57:53.024 From INT Control 1 Bank Select 54
09:57:53.024 From INT Control 1 Bank Select (fine) 56
09:57:53.044 From INT Control 1 Bank Select 59
09:57:53.044 From INT Control 1 Bank Select (fine) 116
09:57:53.064 From INT Control 1 Bank Select 65
09:57:53.064 From INT Control 1 Bank Select (fine) 0
09:57:53.084 From INT Control 1 Bank Select 70
09:57:53.084 From INT Control 1 Bank Select (fine) 8
09:57:53.104 From INT Control 1 Bank Select 74
09:57:53.104 From INT Control 1 Bank Select (fine) 116
09:57:53.124 From INT Control 1 Bank Select 79
09:57:53.124 From INT Control 1 Bank Select (fine) 124
09:57:53.144 From INT Control 1 Bank Select 84
09:57:53.144 From INT Control 1 Bank Select (fine) 84
09:57:53.164 From INT Control 1 Bank Select 89
09:57:53.164 From INT Control 1 Bank Select (fine) 64
09:57:53.184 From INT Control 1 Bank Select 94
09:57:53.184 From INT Control 1 Bank Select (fine) 40
09:57:53.204 From INT Control 1 Bank Select 98
09:57:53.204 From INT Control 1 Bank Select (fine) 112
09:57:53.224 From INT Control 1 Bank Select 103
09:57:53.224 From INT Control 1 Bank Select (fine) 36
09:57:53.244 From INT Control 1 Bank Select 107
09:57:53.244 From INT Control 1 Bank Select (fine) 92
09:57:53.264 From INT Control 1 Bank Select 112
09:57:53.264 From INT Control 1 Bank Select (fine) 4
09:57:53.284 From INT Control 1 Bank Select 116
09:57:53.284 From INT Control 1 Bank Select (fine) 8
09:57:53.304 From INT Control 1 Bank Select 120
09:57:53.304 From INT Control 1 Bank Select (fine) 28
09:57:53.324 From INT Control 1 Bank Select 123
09:57:53.324 From INT Control 1 Bank Select (fine) 112
09:57:53.344 From INT Control 1 Bank Select 127
09:57:53.344 From INT Control 1 Bank Select (fine) 84
09:57:53.364 From INT Control 1 Bank Select 127
09:57:53.364 From INT Control 1 Bank Select (fine) 124
09:57:55.485 From INT Control 1 Controller 15 0
09:57:55.485 From INT Control 1 Controller 47 0
- celio
- Membre platine
- Remerciements reçus 72
il y a 6 ans 11 mois #14753
par celio
Réponse de celio sur le sujet X-Touch (complète) et D::light
Bonjour. Je pense que ça peut être lié au protocole HUI qui est un protocole propriétaire pour le contrôle de soft type protools Logic et autre.
Quand je connecte la X32 a dlight je n'utilise pas le protocole hui de mémoire. Je verifierai la semaine prochaine.
D'après la notice du XTOUCH il envoi bien les infos de 0 à 127 sur différents CC.
media.music-group.com/media/PLM/data/doc...20COMPACT_QSG_WW.pdf
À suivre.
Bonne journée.
À suivre.
Bonne journée.
Les utilisateur(s) suivant ont remercié: get974
- get974
- Nouveau membre
il y a 6 ans 11 mois #14754
par get974
Super, merci à toi.
Comme alternative, je pensais peut-être passer par Logic Pro pour contrôler :light. Ça pourrait permettre d'utiliser le X-touch comme contrôleur de :light... En mode recherche sur le forum du coup...
- celio
- Membre platine
il y a 6 ans 11 mois #14755
par celio
Tu dois pouvoir l'utiliser même sans passer par Logic.
Juste voir sur le xtouch si il peut fonctionner autrement qu'en mode hui (c'est d'ailleurs quasiment sur que ça marche en
Utilisant directement les sorties midi physique mais il n'y a pas de raisons que ça ne marche pas non plus en USB midi....
- get974
- Nouveau membre
il y a 6 ans 11 mois #14757
par get974
Ben si tu veux sur la X-touch version complète tu ne peux choisir que ces modes:
1: Mackie Control en USB / MIDI ou NETWORK
2: H U I en USB / MIDI ou NETWORK
3: Xctl (pour contrôler un rack X32 ou XR18) en MIDI ou NETWORK
4: Xctl + Mackie control
5: Xctl + H U I
Et il n’existe aucun éditeur midi pour cette machine, j'ai tout de même essayé l'éditeur de la compacte... pas compatible... LOL
Peut-être qu'une bidouille au niveau de l'OSC pourrait faire l'affaire?
5: Xctl + H U I
- get974
- Nouveau membre
il y a 6 ans 11 mois #14788
par get974
Suite à échange, un ami possesseur (et grand connaisseur) d'un raspberry Pi est persuadé qu'on peut utiliser :Light sur le raspberry et du coup profiter d'un logiciel d'édition MIDI pour modifier le comportement de la X-Touch... On va essayer de se caler tous les deux avec tout le matériel et étudier une possibilité... affaire à suivre, même si pas beaucoup de personne ne se trouve dans cette situation, ça pourrait être intéressant de faire fonctionner cette X-Touch avec :Light...
Je vous tiens au courant de ce qui ressortira de cet essai...
Temps de génération de la page : 0.506 secondes
