Device editing / ETC S4 LED
il y a 10 ans 9 mois #11722 par Wilf
Réponse de Wilf sur le sujet Device editing / ETC S4 LED
I have currently two shows and both
crash. Here they are.
Fichier en pièce jointe :
Nom du fichier : Samba Schu...GOED.sho
Taille du ficher :40.14 Ko
Nom du fichier : Kusje erop 10.sho
Taille du ficher :53.3 Ko
il y a 10 ans 9 mois #11731 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Device editing / ETC S4 LED
ok,
I think I've found and fix the issue...
b56 is coming
thanx for testing when release,
il y a 10 ans 9 mois #11732 par sl1200mk2
b56 is available for X8_X9
thanx for testing.
Les utilisateur(s) suivant ont remercié: Wilf
il y a 10 ans 9 mois #11744 par Wilf
I'll test it, thanks :)
il y a 7 ans 3 semaines #18957 par birt
Réponse de birt sur le sujet Device editing / ETC S4 LED
sorry for bringing up an old topic.
i tried the hsi profile made by Wilf but i couldn't get it working. (i tried this because ETC reccomends it for theatre applications)
then i tried the standard/direct profile and that works, but the colors are off. because i'm using a Series2 i changed white to yellow (ETC says lime which is more accurate) but then the colors are even further off.
so how would i get accurate color mixing with these devices? should i spend a lot of time to make my own colors and save them? how do others do this? (using an ETC console works great and the colors will be super accurate, i know...)
i have always just used LEE filters on incandescent fixtures and i guess i'm used to the luxury of having consistant results.
il y a 7 ans 3 semaines #18958 par sl1200mk2
Hi Birt,
unfortunately ETC x7 colour mixing is proprietary protocol and it's not like they'll share their code with me...
I've tried hard to understand and code for that x7 system but without engenering data i didn't succeed.
Les utilisateur(s) suivant ont remercié: birt
il y a 7 ans 3 semaines #18959 par birt
hmm, so if you use an ETC Ion with one of these profiles and put a DMX tester in between that monitors the signal... you could read out values for the colors B)
il y a 7 ans 3 semaines #18960 par sl1200mk2
when I want to do real matching colours with ETC fixture, I use an android app (made by ETC) called MyETC:photometrics.
it gives me each channels levels for a specific color.
Temps de génération de la page : 0.148 secondes
