3.0.13
il y a 13 ans 7 mois #5913 par sl1200mk2
3.0.13 a été créé par sl1200mk2
Panic Pure!
this is a fix of the previous release.
It's available for each supported platforms (macOS 10.5->10.8, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
Please be aware that this should be the last available release for Windows XP systems.
Please be aware that this should be (as usual) the last available release for MacOX 10.5 systems.
but this time, I mean it.
thank you for everyone who helped during the beta process.
news:
General:
- New 'Scene Master' (control via OSC (/seq/master xxx) and Midi). Allow to dim channel's that have a level in the active working register.
- DMX Universe / Channels Universe have been cleaned... here comes 'ROOMs' for channel.
that mean that 1 Room = 512 channels, 2 Room = 1024 channels, etc...
MIDI:
- Master (eg AllSubMaster, FlashMater, GrandMaster, SceneMaster, Joystick) have now their levels exported.
- You're now able to select between several Input/Output
- Channel's level are now exported to Midi Out.
- New 'Script' button to load a default Midi Patch
OSC:
- You're now able to use several IP/Port as output.
Time:
- You can now set 0.01 as time for xfade, wait, etc...
Sample:
- There's no need to set a time length to record a sample. just push the button (elapsed time is displayed) and stop it when you want. a maximum of 1 hour can be recorded.
Shortcut:
- standard shourtcuts now include &é"'(§è!çà as 1234567890
ChannelTrack:
- Better behavior when a lot of channels are loaded.
and several bug fixes, enhancements, etc...
If you appreciate the software, please consider making donations.
Enjoy.
Nicolas BATS
il y a 13 ans 7 mois #5916 par Jefff
Réponse de Jefff sur le sujet 3.0.13
J'ai un pb avec les commandes SysEx midi :
quand on clique sur connect :
SysEx identifié en play devient SysEx Stop
SysEx identifié en rewind devient Record (launch In)
Ce qui a pour résultat de ne pas fonctionner.
il y a 13 ans 7 mois #5917 par Jefff
Je viens de vérifier sur la dernière beta c'est pareil. En tout cas c'est super ce temps en 0.01 ! Ça a l'air beaucoup plus précis !
il y a 13 ans 7 mois #5918 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.13
putain :angry:
je suis bon pour une 14
il y a 13 ans 7 mois #5919 par Jefff
Nan... Vire-la discrètement puis l'air de rien tu la remets... ;-)
il y a 13 ans 7 mois #5920 par sl1200mk2
et dire que c'est déjà corrigé...
mais là 3 mails par jour, les gens vont péter les plombs...
en tout cas si t'en as d'autres comme ça, hésites pas...
je vais voir si je peux mettre la 14 en ligne demain, mais c'est pas sur, sinon jeudi.
il y a 13 ans 7 mois #5922 par colinc
Réponse de colinc sur le sujet 3.0.13
Hi Nico,
Same problem with 3.0.13 as with 3.0.12
Les utilisateur(s) suivant ont remercié: paucurses
il y a 13 ans 7 mois #5923 par bgoubert
Réponse de bgoubert sur le sujet 3.0.13
salut Nico,
Je commence les test de la nouvelle mouture ,13.
1° truc sous OSC la syntaxe pour ouvrir la fenêtre de check /checkcirc/launch ne l'ouvre que fugitivement. Elle redisparait aussitôt dès qu'on lache le bouton.
Sinon pour l'instant ouverture normale de copies d'anciennes conduites.
A suivre.
Mac os 10.7.5 Iphone, touch osc.
il y a 13 ans 7 mois #5926 par paucurses
Réponse de paucurses sur le sujet 3.0.13
Hello
I have a question regarding the new d: light (.13 version) ... The shows recorded in past versions are supported? I do not show load?
You can make donations apartir PayPal?
Thanks for this great work! ;)
il y a 13 ans 7 mois #5927 par paucurses
Hello
One of the mistakes that we want to create a new woman when is this show ..!
Mar. 19, 2013 07:44:12
Document not parsed successfully.
Recover XML doc did not work.
I will not let me upload past shows ... What hapen?!
I hope to answer ... Thank you!
il y a 13 ans 7 mois #5928 par paucurses
Hello
To me it's the same problem .. How can solocionar? What happens in reality?
Thank you!
il y a 13 ans 7 mois #5929 par DBO Olivier IRTHUM
Réponse de DBO Olivier IRTHUM sur le sujet 3.0.13
Hello Nicolas,
Je viens d'essayer un nouveau fichier avec la dernière release 3.0.13 de D::Light.
Sous Mac osx 10.7
Apparement en shiftlock les touches :
é( pour 2)
è(pour 7)
ç(pour 9)
à(pour 0)
Ne fonctionnent pas.
Voilà pour info je sais pas si c'est un petit bug ou bien.
But if it can help!!
Bye
il y a 13 ans 7 mois #5930 par sl1200mk2
@Colin,
can you please post your sho.
it's strange because I've made some tests to fix the bug....
thanx
il y a 13 ans 7 mois #5932 par sl1200mk2
@bgoubert,
fais gaffe à ce que ta commande ne renvoie pas 0 quand tu relache le bouton
@PauCurses
maybe there's still a mistake with 13 as Colin pointed out
@Olivier,
avec un nouveau fichier, tu dois pas être obligé de te mettre en CapsLock (Shiftlock, je sais pas ce que c'est...) pour accéder aux chiffres.
si tu tapes directement & par example tu devrais pouvoir accéder au 1.
c'est pas le cas?
il y a 13 ans 7 mois - il y a 13 ans 7 mois #5937 par sl1200mk2
@Colin,
would you mind hacking a little bit....
in the file called DLight.tcl in the /bin directory, at the very end you will find that code
Code:
proc myHomeEnv {} { return [list $::env(HOME)] }
can you try 2 things, first remove some part of the code to looks like that
Code:
proc myHomeEnv {} { return $::env(HOME) }
and relaunch DL and try to open a sho
if it's not enough, can you try like that
Code:
proc myHomeEnv {} { return $env(HOME) }
if it works, can you try like that
Code:
proc myHomeEnv {} { return [list $env(HOME)] }
thanx
Temps de génération de la page : 0.227 secondes
