adventures with RaspberryPi 4
7 years 2 months ago #18754 by sl1200mk2
adventures with RaspberryPi 4 was created by sl1200mk2
j'ai donc fait l'acquisition d'un RaspberryPi 4 :
www.raspberrypi.org/
L'idée est de produire un paquet (.deb) pour que D::Light puisse fonctionner sur ce matériel.
au premier démarrage du Pi, j'ai suivi ces étapes pour le mettre à jour:
STEPS
Follow on-screen instructions until the prompt for input is reached.
Instead of doing, I believe the usual sudo apt-get update && sudo apt-get upgrade -y
DO sudo apt update -y
THEN when complete, do reboot followed by the usual sudo apt-get update && sudo apt-get upgrade -y
THEN when complete, do reboot followed by the usual sudo apt-get dist-upgrade -y
super, le Pi est à jour...
more to come
7 years 2 months ago #18761 by sl1200mk2
Replied by sl1200mk2 on topic adventures with RaspberryPi 4
toutes les librairies nécessaires à DL sont compilées pour le rPi4
The following user(s) said Thank You: mephistium
7 years 2 months ago #18762 by sl1200mk2
good job :)
7 years 2 months ago #18789 by Poypoy
Replied by Poypoy on topic adventures with RaspberryPi 4
ça marche???
7 years 2 months ago #18790 by sl1200mk2
grave :)
quand ça sera ok je vous le dirais
7 years 1 month ago #18844 by dFVarela
Replied by dFVarela on topic adventures with RaspberryPi 4
That is great, can't wait to test it!
What's the monitor that you are using?
dFVarela
dFVarela
7 years 1 month ago #18878 by sl1200mk2
Hi Daniel,
it's a microHDMI monitor... nothing fancy here... :)
7 years 1 month ago - 7 years 1 month ago #18916 by dFVarela
Hi Nico,
I've not made the question properly...What i'll be the minimum resolution?
Being able of using the raspberry pi touch screen would be great! :woohoo: :woohoo:
dFVarela
Last edit: 7 years 1 month ago by dFVarela.
7 years 1 month ago #18918 by sl1200mk2
Hi Daniel,
I'll launch the pi4 and tell you the minimum resolution... but I think it's more or less 800x600.
so I doubt it'll fit with the pi touch screen
7 years 1 month ago #18940 by sl1200mk2
@Daniel,
1280x864, otherwise, you won't get the whole window
by the way it works great :)
does someone have a pi4 for testing?
The following user(s) said Thank You: lejojor
7 years 1 month ago #18941 by dFVarela
The pi monitor is 800x480... :(
Not yet... Next week i'll be in Dublin, but when get back home i'll be buying one, 4Gb i think that's what you'll be recomending!
Just 2 questions:
Are you having problems with the heat?
Do use a RTC?(or advive to use one!)
dFVarela
dFVarela
7 years 1 month ago #18942 by sl1200mk2
the raspbian fit on 16GB microSD
not when outputting DMX thru wifi (via sACN).
I didn't check with usbDMX.
no... I think the more generic it's the better it's
a runnning chaser over 512 channels (each together fading from 0 to FF) consume 9% of the CPU.
easy for the pi :)
7 years 3 weeks ago #19043 by dFVarela
I meant 4GB ram, or is the 1GB ram enough?
The only problem of not using a RTC is you will always have to connect to internet in order to have date/time set correctly!
dFVarela
7 years 3 weeks ago #19044 by sl1200mk2
About the RAM, yeah I realised after more readings what you were talking about.
I've the 4gb one.
About the RTC, in DL point of view you'll need internet connection for licence activating/deactivating and every 3 month.
Apart from that, no need for internet so not really for for an rtc kernel.
My thought is that DL needs to run on a generic raspbian for anybody to use it without pain. If you decide to run it with arch, send me your distribution and I'll compile all libraries for DL to work.
I think it's a nice addition to supported platforms....
7 years 3 weeks ago - 7 years 3 weeks ago #19046 by dFVarela
Got my PI today, if you need testing...
dFVarela
Last edit: 7 years 3 weeks ago by dFVarela.
Time to create page: 0.217 seconds
