NANO KONTROL 2
9 years 11 months ago - 9 years 11 months ago #13677 by santiago
NANO KONTROL 2 was created by santiago
hello friends does not me nano kontrol 2 with d :: light, the input is not in....
help????
Last edit: 9 years 11 months ago by aroom.
9 years 11 months ago #13679 by aroom
Replied by aroom on topic NANO KONTROL 2
it's not easy to help you if you don't give us more info about your operating system, D::Light version, etc
the korg nano control 2 is usually really easy to set up. plug and play. it seems like your computer usb port is defect ?
please give us more infos
The following user(s) said Thank You: santiago
9 years 11 months ago #13681 by santiago
Replied by santiago on topic NANO KONTROL 2
i have windows 8 and use my enttec usb pro mk2 with d:light (versión DL.3.0.24 x8 x9) the software working ok but dont can configure nano kontrol 2.
In the section SETUP / MIDI only appears the nano kontrol 2 in the outputs ,but no in the input.
In other softwares (nano kontrol2) dont have problem.
9 years 11 months ago #13682 by got
Replied by got on topic NANO KONTROL 2
Hello Santiago
I think you must use this : DL_Win32_Install_3.0.24 for windows the X.8 X.9 it's for the mac, if I say wrong.
But the better for you it's to use DL_Win64_Install_4.0.0_b75 (You could find it in section Beta, and not software)
Plug your nanok 2
In section setup/midi switch on the red LED
Do a refresh
It will be appears in Input
switch the button available
normaly that's it, if not use an other port USB like aroom says.
see you
9 years 11 months ago - 9 years 11 months ago #13688 by santiago
Great, works!
One last question: how to avoid latency when moving the faders?
Last edit: 9 years 11 months ago by santiago.
9 years 11 months ago #13697 by sl1200mk2
Replied by sl1200mk2 on topic NANO KONTROL 2
Hi,
where did you have latency?
9 years 5 months ago #14810 by MathieuBarche
Replied by MathieuBarche on topic NANO KONTROL 2
Je viens d’acheter un clavier MIDI nanoKONTROL2, le basic, et j’ai un petit problème pour arriver à le configurer avec D::Light.
J‘arrive très bien à lier les commandes aux submaster, channel et fade, les CC... Mais je n’arrive pas pour tout ce qui est NOTE ou PC.
L’interface me dit pourtant que c’est bien connecté :
GO => Ch#1 Note 0 (C-2)
Mais concrètement, le GO ne se lance pas...
Savez-vous quel est le problème ? Est-ce qu’il faut configurer le clavier MIDI avant de l’utiliser ?
Merci.
Mathieu
9 years 5 months ago #14811 by aroom
oui il faut configurer le contrôleur midi
tout est expliqué dans le WIKI
9 years 5 months ago #14812 by MathieuBarche
Justement, je trouve dans le WIKI comment assigner le contrôleur MIDI, ce que j’arrive à faire, mais pas comment configurer le contrôleur MIDI.
9 years 5 months ago - 9 years 5 months ago #14813 by aroom
Last edit: 9 years 5 months ago by aroom.
9 years 5 months ago #14823 by aroom
alors ça fonctionne ?
The following user(s) said Thank You: MathieuBarche
9 years 5 months ago #14824 by MathieuBarche
Oui, ça y est, j’ai compris grâce au lien URL que vous m’avez envoyé.
Mais, c’est dit très rapidement qu’il faut assigner les touches en mode NOTE. Heureusement que vous m’en avez parlé.
Merci beaucoup.
Bonne journée.
9 years 4 months ago #14864 by LaffreuxBill
Replied by LaffreuxBill on topic problème d'assignation Korg NanoKontrol 2
Bonjour, je viens de faire l'aquisition d'un Korg NanoKontrol 2, presque tout fonctionne : j'arrive à assigner les faders, les potards, certains switchs mais je ne trouve pas dans D::Light de quoi assigner mes boutons "track", "rec" etc...
En fait je ne trouve pas dans le menu défilant la possibilité de choisir le "go" et les "solo" de chaque sub.
Je pense que c'est une manip' toute bête mais je ne trouve pas mon erreur... :hail:
Ps: j'aurais aimé que le git proposé ici ( github.com/dlight-tools/dlight-midi/tree/master/nanokontrol2 ) fonctionne mais je n'arrive pas à l'importer, c'est pourtant exactement le patch que je cherche.
Merci d'avance!!
9 years 4 months ago #14865 by aroom
Replied by aroom on topic problème d'assignation Korg NanoKontrol 2
tu dois changer les touches de ton contrôleur en NOTE
c'est documenté dans notre WIKI et dans de nombreux postes sur le forum.
je vais jeter un oeil au patch, mais d'abord il faut que tu configure ton contrôleur
9 years 4 months ago #14866 by aroom
j'ai regardé le patch, il marche bien. il suffit de l'ouvrir dans le logiciel de Korg et de le transmettre à ton contrôleur.
Time to create page: 0.212 seconds
