[ATTENTION] Apple Bug
5 years 3 weeks ago - 4 years 8 months ago #22072 by sl1200mk2
[ATTENTION] Apple Bug was created by sl1200mk2
Bonjour à tous,
Il apparait que suite à l'expiration d'un certificat de sécurité ( www.identrust.com/support/announcements ) dont sont victimes tous les macOS < 10.15.7 l'activation / désactivation des clés de licences ne fonctionnent plus !!!
téléchargez ce fichier , dézippez le et double-cliquez dessus pour installer de nouveaux certificats de sécurité.
à un moement donné le terminal vous demande votre mot de passe, inscrivez le (il n'apparait pas à l'écran) et validez par Enter
File Attachment:
File Name: appleBug.command.zip
File Size:717 B
It seems that after a certificate expiration ( www.identrust.com/support/announcements ) which concerns all macOS < 10.15 you are not allowed anymore to activate/deactivate licence key.
you can download this file , unzip it and run it (double-click on it).
at some point the Terminal will ask you for your password but does not prompt it while typing, validate with Enter
sorry about that, thanks Apple...
File Attachment:
File Size:717 B
Last edit: 4 years 8 months ago by sl1200mk2.
5 years 3 weeks ago #22073 by sl1200mk2
Replied by sl1200mk2 on topic [ATTENTION] Apple Bug
untested...
voici ce que j'ai trouvé de plus pertinent sur le net sans passer par un update du système:
For older macOS, try:
downloading letsencrypt.org/certs/isrgrootx1.der
Open the Keychain Access app and dragging that file into the System folder of that app.
then find the ISRG Root X1 certificate in System and double click on it, open the Trust menu and change "Use System Defaults" to "Always Trust", then close that and enter your password to confirm the change (if prompted).
5 years 3 weeks ago #22074 by ASSSCCL
Replied by ASSSCCL on topic [ATTENTION] Apple Bug
Hello. I have an important show in two days and it's impossible for me to update to 10.15...
I have tried the ISRG Root X1 certificate method with no luck...
Any other option please??
5 years 3 weeks ago - 4 years 8 months ago #22076 by sl1200mk2
The following user(s) said Thank You: claradlight, ASSSCCL
5 years 3 weeks ago #22078 by ASSSCCL
It looks like it worked!
Wow, thank you so much... for the quick response and the complex solution!
Do you think it can last for a while? I should update soon, but just to know if it should be ok now without this certificate around.
5 years 3 weeks ago #22079 by sl1200mk2
@asssccl
I'm glad you sorted out :)
may I ask you which is your macOS system?
as the certificate have expired, there should be no problem without it
5 years 3 weeks ago #22080 by ASSSCCL
I'm using 10.13.6 (High Sierra) with DLight 4.1.09.
5 years 3 weeks ago #22081 by sl1200mk2
thanks.
after your sho I suggest you to update your DL version to the latest one...
The following user(s) said Thank You: ASSSCCL
5 years 3 weeks ago #22090 by claradlight
Replied by claradlight on topic [ATTENTION] Apple Bug
Problème rencontré lors de mon renouvellement de Licence aujourd'hui sous Mac OS High Sierra version 10.13.6, impossible d'activer la nouvelle clé ! (j'utilise la version D:Light 4.2.08)
J'ai suivi les manips dans le terminal expliqué au dessus, ça peut faire peur mais ça fonctionne !!
Je vais quand même songer à faire une mise à jour de Mac OS !!
5 years 3 weeks ago - 5 years 3 weeks ago #22091 by aroom
Replied by aroom on topic [ATTENTION] Apple Bug
Même problème chez moi sous macOS High Sierra 10.13.6
L'option de rajouter les certificats ISRG Root X1, ISRG Root X2 et Let’s Encrypt R3 dans le keychain Access n'a pas résolu le problème concernant la license de D::Light ( www.pratishkumar.com/dst-root-ca-x3-expi...tember-2021/#the_fix ). Effacer DST Root CA X3 directement depuis keychain Access non plus.
Le texte à enlever était un peu différent chez moi dans /etc/ssl/cert.pem
Mais en gros après avoir retiré tout le pavé de texte concernant DST Root CA X3, depuis "Certificate:" jusqu'à "END CERTIFICATE" ça marche! merci Nico.
Last edit: 5 years 3 weeks ago by aroom.
5 years 3 weeks ago #22115 by gaspard013
Replied by gaspard013 on topic [ATTENTION] Apple Bug
Hello, ça a fonctionné chez moi aussi.
Mac OS High Sierra 10.13.6.
DLight 4.2.01 b1
J'entends bien que c'est un problème indépendant de ta volonté, mais ne serait-ce pas possible, le temps d'intégrer et de corriger ce "bug" d'Apple dans une prochaine version, de "libérer" temporairement les validations de licence ? Et de repasser Dlight en libre pendant 2 ou 3 semaines ? Histoire de ne pas avoir à paniquer à chaque régie alors qu'on a une licence valide ?
Nous sommes beaucoup à utiliser plusieurs ordis et à devoir régulièrement (dés)activer nos licences, c'est quand même pas mal de stress ces derniers jours...
Merci en tout cas pour l'option proposée (et fonctionnelle), sans savoir si ça n'expose pas nos macs à d'autres risques...
5 years 3 weeks ago #22116 by sl1200mk2
@gaspard,
le mot d'ordre dicté par Apple quand tu utilises des machines Apple c'est "keep your computer up to date"
et si tu ne peux plus updater ta machine c'est change ta machine...
Je ne peux pas libérer DL du système de clé de licence comme tu le proposes, faut vraiment arriver à contourner leur bug d'OS.
Et je sais que vous êtes nombreux à échanger les clés et c'est pour ça que crois moi j'essaye de trouver un fix...
5 years 3 weeks ago #22117 by sl1200mk2
breaking NEWS !!
Je viens d'uploader une 4.2.08-1 (pour macOS10.9 Minimum) qui doit résoudre les problèmes d'activation/désactivation des clés de licences.
pour ceux qui utilisent macOS10.9, macOS10.10 et macOS10.11 il faut tout de même que vous fassiez une petite manip pour mettre à jour certains certificats (c'est plus simple que la méthode précédente...)
-ouvrez un terminal (/Applications/Utility/Terminal)
-inscrivez les lignes suivantes les unes après les autres(et validez par Enter à chaque fois):
Code:
cd ~
Code:
curl -k https://letsencrypt.org/certs/isrgrootx1.pem --output isrgrootx1.pem
Code:
curl -k https://letsencrypt.org/certs/isrg-root-x2.pem --output isrg-root-x2.pem
Code:
sudo security add-trusted-cert -d -r trustRoot -k "/Library/Keychains/System.keychain" "isrgrootx1.pem"
à ce moment là le terminal vous demande votre mot de passe, inscrivez le (il n'apparait pas à l'écran) et validez par Enter
Code:
sudo security add-trusted-cert -d -r trustRoot -k "/Library/Keychains/System.keychain" "isrg-root-x2.pem"
Et à partir de là vous devriez pouvoir activer/désactiver vos clés de licence.
Donc pour résumer, tous les utilisateurs de macOS < 10.15.7 vous devez utiliser la version 4.2.08-1 de DL et tout ceux qui on des macOS inférieur à 10.12 doivent faire la manip décrite ci-dessus.
dites moi si c'est ok.
I've just uploaded DLK 4.2.08-1 (macOS10.9 Minimum) which should fix activation/deactivation issues.
For those who still use macOS10.9, macOS10.10 et macOS10.11 you'll need an extra step to update some certificates, it's in the Terminal but it's a lot easier than previously.
-open a Terminal (/Applications/Utility/Terminal)
-write each of the following commands (and validate with Enter each times)
Code:
cd ~
Code:
Code:
Code:
at this stage Terminal will ask you for your password but does not prompt it while typing, validate with Enter
Code:
and then you should be able to activate/deactivate your licence key.
So to sum up, if you run a macOS < 10.15.7 you'll need to use DL 4.2.08-1 and for those that run macOS < 10.12, you'll need Terminal's extra steps.
tell me if it's ok.
The following user(s) said Thank You: guilmay, samolo, Richie, Strobovich
5 years 3 weeks ago #22118 by Rv15
Replied by Rv15 on topic [ATTENTION] Apple Bug
Merci , j'ai installé la nouvelle version pour OS 10.9 ; avec un mac OS 10.13 et cela fonctionne direct je peu enfin intervenir sur la clef
Encore Merci Nicolas .
RV
5 years 3 weeks ago #22122 by ehlaroche
Replied by ehlaroche on topic [ATTENTION] Apple Bug
j'ai téléchargé la version DL 4.2.08-1 et exécuté la manip sur terminal mais rien n'y fait. Il ne me demande qu'une fois mon MDP, rien après la dernière ligne de "scudo security" et termine par ceci : ***Error reading file isrgrootx1.pem
J'ai également essayé les opérations "sudo nano" que tu suggérais plus haut mais terminal ne trouve pas de fichier DST Root CA X3.
Je tourne habituellement sur OS.10.10 et DL 4.1.06
Time to create page: 0.209 seconds
