- Thank you received: 1083
[ATTENTION] Apple Bug
Il apparait que suite à l'expiration d'un certificat de sécurité ( www.identrust.com/support/announcements ) dont sont victimes tous les macOS < 10.15.7 l'activation / désactivation des clés de licences ne fonctionnent plus !!!
téléchargez ce fichier , dézippez le et double-cliquez dessus pour installer de nouveaux certificats de sécurité.
à un moement donné le terminal vous demande votre mot de passe, inscrivez le (il n'apparait pas à l'écran) et validez par Enter
It seems that after a certificate expiration ( www.identrust.com/support/announcements ) which concerns all macOS < 10.15 you are not allowed anymore to activate/deactivate licence key.
you can download this file , unzip it and run it (double-click on it).
at some point the Terminal will ask you for your password but does not prompt it while typing, validate with Enter
sorry about that, thanks Apple...
voici ce que j'ai trouvé de plus pertinent sur le net sans passer par un update du système:
For older macOS, try:
downloading letsencrypt.org/certs/isrgrootx1.der
Open the Keychain Access app and dragging that file into the System folder of that app.
then find the ISRG Root X1 certificate in System and double click on it, open the Trust menu and change "Use System Defaults" to "Always Trust", then close that and enter your password to confirm the change (if prompted).
- ASSSCCL
I have tried the ISRG Root X1 certificate method with no luck...
Any other option please??
- ASSSCCL
Wow, thank you so much... for the quick response and the complex solution!
Do you think it can last for a while? I should update soon, but just to know if it should be ok now without this certificate around.
I'm glad you sorted out
may I ask you which is your macOS system?
as the certificate have expired, there should be no problem without it
- ASSSCCL
after your sho I suggest you to update your DL version to the latest one...
- claradlight
J'ai suivi les manips dans le terminal expliqué au dessus, ça peut faire peur mais ça fonctionne !!
Je vais quand même songer à faire une mise à jour de Mac OS !!
L'option de rajouter les certificats ISRG Root X1, ISRG Root X2 et Let’s Encrypt R3 dans le keychain Access n'a pas résolu le problème concernant la license de
:Light (
www.pratishkumar.com/dst-root-ca-x3-expi...tember-2021/#the_fix
). Effacer DST Root CA X3 directement depuis keychain Access non plus.Le texte à enlever était un peu différent chez moi dans /etc/ssl/cert.pem
Mais en gros après avoir retiré tout le pavé de texte concernant DST Root CA X3, depuis "Certificate:" jusqu'à "END CERTIFICATE" ça marche! merci Nico.
- gaspard013
Mac OS High Sierra 10.13.6.
DLight 4.2.01 b1
J'entends bien que c'est un problème indépendant de ta volonté, mais ne serait-ce pas possible, le temps d'intégrer et de corriger ce "bug" d'Apple dans une prochaine version, de "libérer" temporairement les validations de licence ? Et de repasser Dlight en libre pendant 2 ou 3 semaines ? Histoire de ne pas avoir à paniquer à chaque régie alors qu'on a une licence valide ?
Nous sommes beaucoup à utiliser plusieurs ordis et à devoir régulièrement (dés)activer nos licences, c'est quand même pas mal de stress ces derniers jours...
Merci en tout cas pour l'option proposée (et fonctionnelle), sans savoir si ça n'expose pas nos macs à d'autres risques...
le mot d'ordre dicté par Apple quand tu utilises des machines Apple c'est "keep your computer up to date"
et si tu ne peux plus updater ta machine c'est change ta machine...
Je ne peux pas libérer DL du système de clé de licence comme tu le proposes, faut vraiment arriver à contourner leur bug d'OS.
Et je sais que vous êtes nombreux à échanger les clés et c'est pour ça que crois moi j'essaye de trouver un fix...
Je viens d'uploader une 4.2.08-1 (pour macOS10.9 Minimum) qui doit résoudre les problèmes d'activation/désactivation des clés de licences.
pour ceux qui utilisent macOS10.9, macOS10.10 et macOS10.11 il faut tout de même que vous fassiez une petite manip pour mettre à jour certains certificats (c'est plus simple que la méthode précédente...)
-ouvrez un terminal (/Applications/Utility/Terminal)
-inscrivez les lignes suivantes les unes après les autres(et validez par Enter à chaque fois):
Et à partir de là vous devriez pouvoir activer/désactiver vos clés de licence.
Donc pour résumer, tous les utilisateurs de macOS < 10.15.7 vous devez utiliser la version 4.2.08-1 de DL et tout ceux qui on des macOS inférieur à 10.12 doivent faire la manip décrite ci-dessus.
dites moi si c'est ok.
I've just uploaded DLK 4.2.08-1 (macOS10.9 Minimum) which should fix activation/deactivation issues.
For those who still use macOS10.9, macOS10.10 et macOS10.11 you'll need an extra step to update some certificates, it's in the Terminal but it's a lot easier than previously.
-open a Terminal (/Applications/Utility/Terminal)
-write each of the following commands (and validate with Enter each times)
and then you should be able to activate/deactivate your licence key.
So to sum up, if you run a macOS < 10.15.7 you'll need to use DL 4.2.08-1 and for those that run macOS < 10.12, you'll need Terminal's extra steps.
tell me if it's ok.
- Rv15
Encore Merci Nicolas .
RV
- ehlaroche
j'ai téléchargé la version DL 4.2.08-1 et exécuté la manip sur terminal mais rien n'y fait. Il ne me demande qu'une fois mon MDP, rien après la dernière ligne de "scudo security" et termine par ceci : ***Error reading file isrgrootx1.pem
J'ai également essayé les opérations "sudo nano" que tu suggérais plus haut mais terminal ne trouve pas de fichier DST Root CA X3.
Je tourne habituellement sur OS.10.10 et DL 4.1.06
