Device editing / ETC S4 LED
10 years 9 months ago #11722 by Wilf
Replied by Wilf on topic Device editing / ETC S4 LED
I have currently two shows and both
crash. Here they are.
File Attachment:
File Name: Samba Schu...GOED.sho
File Size:40.14 KB
File Attachment:
File Name: Kusje erop 10.sho
File Size:53.3 KB
10 years 9 months ago #11731 by sl1200mk2
Replied by sl1200mk2 on topic Device editing / ETC S4 LED
ok,
I think I've found and fix the issue...
b56 is coming
thanx for testing when release,
10 years 9 months ago #11732 by sl1200mk2
b56 is available for X8_X9
thanx for testing.
The following user(s) said Thank You: Wilf
10 years 9 months ago #11744 by Wilf
I'll test it, thanks :)
7 years 3 weeks ago #18957 by birt
Replied by birt on topic Device editing / ETC S4 LED
sorry for bringing up an old topic.
i tried the hsi profile made by Wilf but i couldn't get it working. (i tried this because ETC reccomends it for theatre applications)
then i tried the standard/direct profile and that works, but the colors are off. because i'm using a Series2 i changed white to yellow (ETC says lime which is more accurate) but then the colors are even further off.
so how would i get accurate color mixing with these devices? should i spend a lot of time to make my own colors and save them? how do others do this? (using an ETC console works great and the colors will be super accurate, i know...)
i have always just used LEE filters on incandescent fixtures and i guess i'm used to the luxury of having consistant results.
7 years 3 weeks ago #18958 by sl1200mk2
Hi Birt,
unfortunately ETC x7 colour mixing is proprietary protocol and it's not like they'll share their code with me...
I've tried hard to understand and code for that x7 system but without engenering data i didn't succeed.
The following user(s) said Thank You: birt
7 years 3 weeks ago #18959 by birt
hmm, so if you use an ETC Ion with one of these profiles and put a DMX tester in between that monitors the signal... you could read out values for the colors B)
7 years 3 weeks ago #18960 by sl1200mk2
when I want to do real matching colours with ETC fixture, I use an android app (made by ETC) called MyETC:photometrics.
it gives me each channels levels for a specific color.
Time to create page: 0.152 seconds
