Device editing / ETC S4 LED
10 years 9 months ago #11702 by Wilf
Replied by Wilf on topic Device editing / ETC S4 LED
WTF?
The personality files, when I open them again, are all mixed up...? They're not how I made them. Are they editable in a text editor?
10 years 9 months ago #11703 by sl1200mk2
Replied by sl1200mk2 on topic Device editing / ETC S4 LED
nope,
this is what I told you... b54 can mix attribut in a strange way if you remove some attribut.
10 years 9 months ago #11704 by Wilf
Ok, I understand now why you said that my personalities weren't correct. I just corrected them. Here they are as bundle, I also fixed the coarse / fine by using the FINE attribute on the HUE attribute.
File Attachment:
File Name: devices.zip
File Size:15.61 KB
10 years 9 months ago #11705 by sl1200mk2
yep, that looks better
you SHOULD set the mode version of your personality in the model field of the personality... otherwise they'll all look the same in the 'device listing'
10 years 9 months ago #11706 by Wilf
Good point, I was thinking about that. I'll change the personalities one more time. :silly:
10 years 9 months ago #11707 by sl1200mk2
thanks.
b55 will be better...
I've also added Ctrl+c Ctrl+v to the personality editor as it's quicker to copy/paste instead of typing....
The following user(s) said Thank You: Wilf
10 years 9 months ago #11708 by Wilf
Looking forward to b55!
I hope these device personalities are better:
File Attachment:
File Name: devices-2.zip
File Size:26.06 KB
I have to admit that I got a bit lazy at Expolite TR16 on channel 11 and 13 which have a lot of macro / auto functions :whistle:
10 years 9 months ago - 10 years 9 months ago #11709 by Wilf
Can you please explain how to clone without b54 crashing? I'm trying everything but nothing works... :blush:
I don't know it's in the show, this is the one (but I've had the same problems with other shows):
File Attachment:
File Name: Show_crash...atch.sho
File Size:40.14 KB
Last edit: 10 years 9 months ago by Wilf.
10 years 9 months ago #11710 by sl1200mk2
you must import a device, set it to a channel and after you can clone it...
if you clone from a device with no ch assigned, it leads to wrong behavior
10 years 9 months ago - 10 years 9 months ago #11711 by Wilf
I do that, I assign it to a channel but it crashes anyway if I clone. 4.0.54b on 10.9.5 with Enttec Mk2
10 years 9 months ago #11712 by sl1200mk2
sorry for that...
here on 10.9 with b55, it clones well
you'll tell me when b55 will be published...
10 years 9 months ago - 10 years 9 months ago #11713 by Wilf
Ok I will. A funny thing just happened: I thought I'd record the crash but then for the first time it did not crash directly but it gave an error message, maybe it is of use for you? It says:
Error: cell index "-1,invPAN" out of range
So it seems 'inverse pan' gives some kind of stack overflow or out of bounds error...?
Edit: When I select 'inverse pan' and don't select 'inverse tilt' I get the same error but then 'invTILT'. When selecting both ticker boxes no cloning will occur but no error will occur too.
Edit 2: Hmmmm... It does crash even when both ticker boxes are selected and I clone after all...
Edit 3: If I don't clone but insert a device on channel 1 and then insert another device and give it channel 2 version 54b crashes immediately too.
Videos are uploading now, I'll edit them in this reply later.
10 years 9 months ago #11714 by sl1200mk2
i've uploaded a b55 for X8_X9
would you mind testing it?
10 years 9 months ago #11715 by Wilf
Tested, alas same behaviour.
10 years 9 months ago #11716 by sl1200mk2
can you post your sho before cloning?
Time to create page: 0.207 seconds
