- Thank you received: 6
4.2.10
- zenerve
4 years 6 months ago #22681
by zenerve
Replied by zenerve on topic 4.2.10
Salut
J'étais en exploit', donc je n'ai téléchargé et mis à jour qu'aujourd'hui ; je confirme le bug "Ouin je veux le tcl comme ci et pas comme çaaaaa" sur Mint et Ubuntu.
D'avance merci
| sh DLight.sh application-specific initialization failed: Can't find a usable init.tcl in the following directories: /usr/local/lib/tcl8.7 {} /home/jph/bin/DLight_4.2.10_Linux_Ubuntu18_Minimum/DLight-64-Linux/lib/tcl8.7 /home/jph/bin/DLight_4.2.10_Linux_Ubuntu18_Minimum/lib/tcl8.7 [...] /home/jph/bin/DLight_4.2.10_Linux_Ubuntu18_Minimum/DLight-64-Linux/lib/tcl8.7/init.tcl: version conflict for package "tcl": have 8.7a4, need exactly 8.7a6 version conflict for package "tcl": have 8.7a4, need exactly 8.7a6 while executing "package require -exact tcl 8.7a6" (file "/home/jph/bin/DLight_4.2.10_Linux_Ubuntu18_Minimum/DLight-64-Linux/lib/tcl8.7/init.tcl" line 22) invoked from within "source /home/jph/bin/DLight_4.2.10_Linux_Ubuntu18_Minimum/DLight-64-Linux/lib/tcl8.7/init.tcl" ("uplevel" body line 1) invoked from within "uplevel #0
This probably means that Tcl wasn't installed properly. |
D'avance merci
- Thank you received: 1066
4 years 6 months ago #22683
Replied by sl1200mk2 on topic 4.2.10
@zenerve
c'est le même issue que sur XQuartz... donc comme avec Olivier, je vais te faire un weTransfer (jph@tuSaisQuoi.net, c'est ça?) avec un update pour voir si c'est mieux.
The following user(s) said Thank You: zenerve
- zenerve
4 years 6 months ago - 4 years 6 months ago #22685
by zenerve
Nope sorry - mais merci de la réactivité !
Toujours le même problème
avec DLight_4.2.10-1_Linux_Ubuntu18_Minimum
""version conflict for package "tcl": have 8.7a4, need exactly 8.7a6
while executing
while executing
Last edit: 4 years 6 months ago by zenerve.
- zenerve
- sonolivier85
- Thank you received: 4
- Poypoy
- Thank you received: 22
4 years 6 months ago #22851
by Poypoy
Replied by Poypoy on topic 4.2.10
J'ai un crash récurrent dans le Personnality Editor.
ça arrive quand j'attaque les couleurs, mais c'est peut-être le hasard.
Pour info, j'édite la personnalité sur un nouveau show non sauvé.
Je vais essayé de le faire sur un show sauvé.
crashLog en PJ
crashLog en PJ
- Poypoy
- Poypoy
4 years 6 months ago #22875
by Poypoy
J'ai exactement le même problème.
ça crash au 2ème offset, ou 3ème, que ce soit de le shunter, la couleur...
Je n'arrive pas à trouver une manip ou un réglage particulier qui provoque le crash
Time to create page: 0.199 seconds
