4.1.09 dev cycle
6 years 8 months ago #19693 by celio
Replied by celio on topic 4.1.09 dev cycle
i test with you show and no problem with 4.1.0.8 native on Mojave
have a nice day
Célio
6 years 8 months ago #19694 by sl1200mk2
Replied by sl1200mk2 on topic 4.1.09 dev cycle
Hi,
me neither I don't succeed to reproduce it...
there should be some steps to reproduce the bug but I don't find them...
@soundsurfer
do you succeed to reproduce it easily?
6 years 8 months ago #19695 by SoundSurfer
Replied by SoundSurfer on topic 4.1.09 dev cycle
Hey,
I tried replicating with a new sho. not possible, but it does with the nabil.sho
here's a video on how it happens:
video link
soundsurfer
6 years 8 months ago #19696 by sl1200mk2
@soundsurfer
did you set a 'theme' on your computer?
in the setup window, the little arrow on attached/detached setting should be blue, not red...
how id you get this?
6 years 8 months ago #19697 by SoundSurfer
Hey Nico,
i captured a video to show you how.
soundsurfer..
6 years 8 months ago #19698 by sl1200mk2
@soundsurfer,
so that was not the faulty part...
what is your screen resolution ? mine is 15,4 pouces (2880 x 1800) (you can got it from About this Mac / Monitor )
6 years 8 months ago #19699 by SoundSurfer
same. macbook pro 2015, 15".
6 years 8 months ago #19700 by sl1200mk2
@soundsurfer,
I really don't know why it behave like that on your computer...
for the next beta, I'll allow the resizing of the main window in attached mode. you'll tell then how it goes.
6 years 8 months ago #19701 by sl1200mk2
@me
cf Nabil.sho from soundsurfer, en @mode quand on fait Cmd+Q, DL inscrit [CUE] dans la ligne de commande... il ne devrait pas...
6 years 8 months ago #19704 by celio
Salut Nico, est-ce qu’il y aurait moyen que d Light transmettre une info osc quand on clique sur le toggle d’un Sub. Et si possible la même info que quand on clique sur flash à savoir /subStick/x/level ?
Bonne journée.
Célio.
6 years 8 months ago #19706 by sl1200mk2
4.1.09_b1 is online.
-Park:
is now registered with the sho
-Palette:
you can now use floating numbers for Palettes (2.1 or 2.05 for exemple)
@Celio
les MLinks doivent controler les sub en Toggle.
Par rapport à ta demande et l'OSC, je ne pense pas pouvoir sortir un /subStick/x/level lors de l'appui sur Toggle, au mieux un nouveau message mais pas celui là...
@soundsurfer
you should be able to resize the main window when display is 'attached'
merci de vos retours,
6 years 8 months ago #19707 by celio
Merci Nico. Un autre message ce serait déjà super.
6 years 8 months ago #19723 by sl1200mk2
4109_b2 Native is available for macOS, it should address 'Balance' bug on this platform
6 years 8 months ago #19735 by SoundSurfer
Hey Nico,
On mac Catalina;
I make the window attached, and then full screen, everything is great.
I really like the feature that the patching window that i open with cmd+p opens as a tab!
w:woohoo: w:woohoo: w:woohoo:
THANK YOU!
SoundSurfer
6 years 7 months ago #19755 by sl1200mk2
does someone run the macOS native on Mojave?
