4.0.0_b66
10 years 5 months ago #12535 by sl1200mk2
4.0.0_b66 was created by sl1200mk2
A que quieres jugar?
here's a new shot...
I've finished what I want to put in DL before the 4.x release
some others beta may come but mainly for bug fixes.
news:
-listed here ( getdlight.com/index.php/forum/2-releases/5861-pre-4-0-0-b66 )
-bug fixes
few words about the new 'Phase' ID for a submaster:
one can freely navigate in a sample thanks to the new phase function. it starts at 0.0 and end at 1.0 (1.0 is the latest frame of the sample).
so you can set a sub as Phase for a sample (like you did with Speed function), and you have 255 steps to navigate in the sample.
I've also added OSC message (/sub/x/phase 0.0........1.0).
thus, you have a huuuuuuge precise control over the sample's restitution.
you can go forward, backward, loop inside, etc.....
enjoy and please shout about it
The following user(s) said Thank You: zenerve
10 years 5 months ago #12536 by nomatter
Replied by nomatter on topic 4.0.0_b66
Thanks and Testing.
One little thing in Device Command Parser: if I digit 18h (for group 18) and then 26- (to remove one device of group) it says No group 26.
Bye,
Carlo.
10 years 5 months ago #12538 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b66
Hi Carlo,
ok, I'll check that...
10 years 5 months ago #12556 by passa
Replied by passa on topic 4.0.0_b66
isn't it normal? if yu start calling a group, next number will be interpreted as a group, not as a channel; same logic as with submasters. But sould be nice indeed to be able to add or remove channel from a group selection, and to add or remove a group from channel selection.
10 years 5 months ago #12557 by nomatter
That's what I thought too.
Parser probably it's good and works this way in every part of the program.
But could be nice to find a way to add or remove channels on fly.
Carlo.
10 years 5 months ago #12571 by boeckel
Replied by boeckel on topic 4.0.0_b66
Hello Nico,
Chez moi cette version crash direct après "load submaster" lorsque je charge mon projet.
que ce soit la version pour X10-11 ou X8-9 donc sur Mac et deux machines différentes.
Ce n'est évidement pas le cas en 4b64 ou inférieur.
ci joint le log et mon show.
Merci de ton aide.
File Attachment:
File Name: APDP DL4b6....sho.zip
File Size:584.88 KB
File Attachment:
File Name: DLight_201...rash.zip
File Size:15.01 KB
10 years 5 months ago #12573 by sl1200mk2
@Pascal,
effectivement...
je vais fixer ça.
thanx
10 years 5 months ago #12574 by sl1200mk2
@Pascal
dans la section Download/alpha du site, je viens de publier une preview de la b67 qui devrait fixer le pb.
peux-tu essayer et me dire?
10 years 5 months ago #12576 by sl1200mk2
@Carlo,
about 18 h 26 -
it's indeed the way DL handle channel/group selection
and as you've discover, it's not perfect, but it's like that....
if you set selection to behave for groups, you cannot - channels inside
10 years 5 months ago #12578 by boeckel
IMPECCABLE !
J'ai testé deux trois manip. ça baigne.
Je l'ai aussi essayé sur une autre projet où ça ne plantait pas,...belle couleurs sur les Sub...sympa, mais
Par contre, je veux bien que tu nous re-explique brièvement à quoi ça sert ce "Phase" ?
10 years 5 months ago #12579 by sl1200mk2
la Phase, c'est le délire.... B)
tu créer un sample, tu le charges dans un sub
tu assignes un autre sub comme phase de celui qui contient le sample
tu mets à FF (ou autre) le niveau du sub qui contient le sample
et avec celui qui est phasé tu te balades à l'intérieur du sample.
essayes c'est pas long à faire et c'est explicite
10 years 5 months ago #12580 by boeckel
Ok, ce qui m'a mis sur la piste c'est que tu disais que c'est comme pour le "speed" donc j'ai essayé avec le speed.
Et j'ai vu que tu pouvais associer un Speed à un chase sur un Sub et que du coup ils auraient la même couleur.
Maintenant , le sample, je sais ce que c'est en son, mais en lumière ????
10 years 5 months ago #12581 by sl1200mk2
à partir de maintenant ta vie va changer.... ;)
j'ai vu un petit loup en essayant de te faire un exemple...
laisse moi updater une nouvelle alpha et je te joins un sho pour te monter
The following user(s) said Thank You: boeckel
10 years 5 months ago #12582 by sl1200mk2
donc j'ai mis un nouvelle alpha en ligne qui fonctionne
et ci-joint un sho test
le sample 2 est un enregistrement de 3 circuits
pour enregistrer le sample 2, j'ai cliqué sur le record du bouton de sample, j'ai monté le circuit 12 à FF à la main, puis redescendu, monté le 13 à FF puis redescend, monté le 14 à FF puis redescend.
et j'ai cliqué sur le bouton record du sample pour l'arreter
j'ai chargé le sample 2 dans le sub 6 et phasé le sub 5 pour le sub 6
je mets le sub 6/FF et après en scrollant le sub 5, je me balade dans le sample
hope it's clear
10 years 5 months ago #12583 by aroom
Replied by aroom on topic 4.0.0_b66
c'est hyper cool
Time to create page: 0.203 seconds
