4.0.0_b58
10 years 8 months ago #11934 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b58
Hi,
I've tested b58 installator on my Mum's PC, and it install fine.
Opening the color selector or using the 'slider' crashes DLight.
same here... fuck de fuck....
will work on that next week.
10 years 8 months ago - 10 years 8 months ago #11945 by dFVarela
Replied by dFVarela on topic 4.0.0_b58
Can't connect to OLA and to OSC server on a machine whit Linux 64b
Code:
Firefox can't establish a connection to the server at localhost:9090
I will try tomorrow on a 32b machine!
dFVarela
Last edit: 10 years 8 months ago by dFVarela.
10 years 8 months ago #11947 by sl1200mk2
@Daniel,
i guess the http data dir & pids dir of OLA aren't fine...
does olad is started?
what you can try is to try to launch olad like:
olad --h
in order to list arguments that olad accepts and specify the --http-dir and --pid-dir
they're both included in DL but links may be faulty.
10 years 8 months ago #11949 by xtineb
Replied by xtineb on topic 4.0.0_b58
Après point de restauration antérieur, la désinstallation c'est faite correctement.
Et du coup La 4.0.0_b58 c'est bien installée ! yess!
(win7 64)
10 years 8 months ago #11950 by sl1200mk2
@xtine,
nice.
c'est quoi un point de restauration antérieur?
et à ton avis, pourquoi ça n'a pas marché la première fois?
10 years 8 months ago #11951 by xtineb
de ce que j'ai compris:
chez windows on a la possibilité de revenir à un état antérieur....ce point de restauration se fait automatiquement quand on installe, désinstalle un programme ou lors de mises à jours windows ou encore mieux on créé soit même son point de restauration. j'ai donc choisi une date en début de mois. (quand l'ordinateur me paraissait tout bien!)
pourquoi çà n'a pas marché avant?
no lo sait !
en tout cas je suis contente que celà fonctionne !
biz
10 years 8 months ago #11957 by dFVarela
On a Linux 32b OSC and OLA Server seems to be OK! I'll check out the 64b better later, or tomorow!
dFVarela
10 years 8 months ago #11970 by dFVarela
@Nico
olad --h
Giving that command gives me te error:
Code:
The program 'olad' is currently not installed. You can install it by typing: sudo apt-get install ola
dFVarela
10 years 8 months ago #11972 by sl1200mk2
olad is included in DL, it's the OLA daemon
10 years 8 months ago #11978 by noror
Replied by noror on topic 4.0.0_b58
j'essaye d'importer cette conduite en ascii sur dlight et elle plante systématiquement, j'ai cependant réussi a importer d'autre ascci en passant sur la version beta 4.0
je suis sur windows 7 62bits
la seule différence avec les autres conduite c qu'il y a dans celle-ci des automatiques...
ta réponse :
@noror,
c'est le patch qui chie en déclarant des circuits 4000, voire 10000.
DL devrait gérer ça cependant.... si tu effaces toutes les infos de Patch de ton fichier, ça doit passer
peux-tu poster un message dans le thread sur la 4.0.0_b58 pour que je m'en souvienne, stp?
je vais donc essayer et te donnerais un retour!
10 years 8 months ago - 10 years 8 months ago #11989 by xtineb
Bonjour à tous,
j'ai utilisé le "personnality editor" : (voir les pj)
avec la 4.0.0_b55 la version 6ch tout est OK
avec la 4.0.0_b58 la version 12ch:
les caractères c et v se comportent comme ctrl+c et ctrl+v
solution adoptée: les majuscules!
PS: j'ai pas reussi à uploader les .dll dans la section download!
Last edit: 10 years 8 months ago by xtineb.
10 years 8 months ago #11990 by hub
Replied by hub on topic 4.0.0_b58 X1 au noir ??
Bonjour à tous
Il m'est impossible de faire le noir en baissant le potentiometre correspondant à X1 sur mon Nanokontrole.
Il y aurait comme une fonction qui maintiendrait l'intensité des circuits communs aux 2 séquences à la plus basse intensité.
Je dois donc programmer un noir pour faire apparaitre une source dés que je le souhaite, la manipe de baisser X1 est plus simple....
De ce fait je me pose la question donc pour des autos, MIB....
10 years 8 months ago #11991 by sl1200mk2
@xtine,
merci pour les persos... cependant:
-mets le HOME à HALF pour le Pan et Tilt, pour que la position initiale ne soit pas 0/0 (tu peux mettre les fine aussi à HALF...)
-pour les définitions de la colour wheel, tu peux utiliser Ctrl-c/Ctrl-v depuis le Pdf pour avoir exactement ce que défini le constructeur (par exemple c'est Peachblow et pas peahblow)
-pour le SHUTTER, mets le HOME à FULL (pour pas qu'il soit éteint quand tu appelle la fonction HOME)
-pour les définitions de GOBO, recopie les données constructeur, c'est important de savoir si c'est slow->fast ou fast->slow
sinon, je comprends pas ce que tu veux dire avec les Ctrl-c/ctrl-v...
si tu les refais, je les uploaderais...
@hub
il y a effectivement une fonction qui maintient le niveau des circuits qui se trouvent présent dans X1 et X2, sans ça, si tu fais un transfert croisé, tu verras ton projo descendre et remonter à la valeur de X2 (si en X2 il est > à X1)
tu peux utiliser le 'SCENE Master' pour faire un noir si tu veux
10 years 8 months ago #11994 by xtineb
merci Nico je vais revoir mes définitions comme il faut mais:
sl1200mk2 wrote: @xtine,
justement c'est mon problème le "c" et le "v" ne fonctionnent pas en minuscule :
ex: quand je tape "v" -> j'ai un "coller" (ctrl+v)
...de même dans la partie "texte" des steps...
biz
10 years 8 months ago #11995 by xtineb
voilà les définitions corrigées !
Time to create page: 0.262 seconds
