3.0.13
13 years 7 months ago #5939 by paucurses
Replied by paucurses on topic 3.0.13
Hi You know when it's solved the problem? There will be a new version (14) or be the same? Thank you. Hope response
13 years 7 months ago #5940 by colinc
Replied by colinc on topic 3.0.13
sl1200mk2 wrote: @Colin,
can you please post your sho.
it's strange because I've made some tests to fix the bug....
thanx
Will do...
13 years 7 months ago #5941 by colinc
Hi Nico
Will do when I get a moment...
would you mind hacking a little bit....
in the file called DLight.tcl in the /bin directory, at the very end you will find that code
Code:
proc myHomeEnv {} { return [list $::env(HOME)] }
can you try 2 things, first remove some part of the code to looks like that
Code:
proc myHomeEnv {} { return $::env(HOME) }
and relaunch DL and try to open a sho
if it's not enough, can you try like that
Code:
proc myHomeEnv {} { return $env(HOME) }
if it works, can you try like that
Code:
proc myHomeEnv {} { return [list $env(HOME)] }
thanx
13 years 7 months ago #5944 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.13
@Colin,
forget about that, please test the 3.0.14_b1
@everybody
a new beta is online for testing
13 years 7 months ago #5945 by bgoubert
Replied by bgoubert on topic 3.0.13
Hello Nico
OSC page Test résolu,
par contre commande Master Scene avec syntaxe "/seq/master" ne marche que dans un sens de DL vers Iphone et pas dans l'autre.
Je reprends les test sur la 0.14.
13 years 7 months ago #5946 by sl1200mk2
bien vu, les autres masters ne doivent pas fonctionner non plus (isn't it?):
/sub/flashmaster
/sub/master
13 years 7 months ago #5947 by sl1200mk2
@b
en fait c'est pas que ça fonctionne pas dans le sens ext->DL, c'est que tu dois envoyer des floats et cette commande n'était écrite que pour des ints.
fixed
13 years 7 months ago #5948 by bgoubert
glup !
what that mean?
je dois modifier les params ou c'est dans ta partie ?
13 years 7 months ago #5950 by Jefff
Replied by Jefff on topic 3.0.13
@Nico ou quelqu'un d'autre :
à quoi servent les ROOMs ???
13 years 7 months ago #5951 by bgoubert
@jefff
c'est les univers DMX
13 years 7 months ago #5953 by sl1200mk2
les ROOMs de circuits:
c'est différent des univers DMX.
1 ROOM, c'est un block de 512 circuits. si tu veux 1024 circuits, tu assignes 2 ROOMs.
depuis chaque ROOM tu peux patcher sur un des 4 univers DMX de sortie.
c'était pas clair avant où univers DMX et univers de circuits coïncidaient. maintenant ils sont distincts.
13 years 7 months ago #5954 by bgoubert
@nico,
j'ai pas trouvé les assignations d'univers. Ca se passe où maintenant ? Dans le setup je vois bien les rooms (bien noté que c'est différent des univers) mais comment fait on pour assigner des rooms à un univers?
13 years 7 months ago #5955 by sl1200mk2
dans le patch., par example:
[CH] [1] [DIMMER] [1] patche le grada 1 du premier univers (le 0) sur le circuit 1
[CH] [1] [DIMMER] [1.1] patche le grada 1 du second univers (le 1) sur le circuit 1
etc...
les ROOMS c'est complètement différent des univers DMX
pour bien comprendre, j'aurais pu ne pas faire de ROOM et faire qu'on puisse inscrire 1024 circuits dans le setup... mais bon, c'est plus lourd à gérer graphiquement (plus de circuits à afficher, etc) et je pense que c'est pas mal mentalement de séparer les circuits qui appartiennent au premier univers DMX (les gradas de la salle qui nous accueille) de ceux qui appartiennent à un autre univers (les projos à adresse avec lesquels on tourne).
13 years 7 months ago #5959 by Jefff
Là je suis largué !!! :-) C'est peut-être que je n'ai jamais eu besoin de plus de 512 circuits (pauvre de moi). Sinon, pour les dons la carte maestro ne passe pas... Un autre moyen ?
13 years 7 months ago #5960 by sl1200mk2
t'as pas besoins de plusieurs ROOM pour patcher sur plusieurs univers DMX, c'est clair ça? et je pense que c'est l'essentiel de ce qu'il faut capter.
si t'as un boitier avec plusieurs univers DMX (genre artistice licence ou dmxking) tu peux utiliser tous les univers de ces boitiers avec une seule ROOM.
non, je sais pas faire autrement... (un chèque peut être...)
Time to create page: 0.183 seconds
