3.0.13
13 years 7 months ago #5913 by sl1200mk2
3.0.13 was created by sl1200mk2
Panic Pure!
this is a fix of the previous release.
It's available for each supported platforms (macOS 10.5->10.8, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
Please be aware that this should be the last available release for Windows XP systems.
Please be aware that this should be (as usual) the last available release for MacOX 10.5 systems.
but this time, I mean it.
thank you for everyone who helped during the beta process.
news:
General:
- New 'Scene Master' (control via OSC (/seq/master xxx) and Midi). Allow to dim channel's that have a level in the active working register.
- DMX Universe / Channels Universe have been cleaned... here comes 'ROOMs' for channel.
that mean that 1 Room = 512 channels, 2 Room = 1024 channels, etc...
MIDI:
- Master (eg AllSubMaster, FlashMater, GrandMaster, SceneMaster, Joystick) have now their levels exported.
- You're now able to select between several Input/Output
- Channel's level are now exported to Midi Out.
- New 'Script' button to load a default Midi Patch
OSC:
- You're now able to use several IP/Port as output.
Time:
- You can now set 0.01 as time for xfade, wait, etc...
Sample:
- There's no need to set a time length to record a sample. just push the button (elapsed time is displayed) and stop it when you want. a maximum of 1 hour can be recorded.
Shortcut:
- standard shourtcuts now include &é"'(§è!çà as 1234567890
ChannelTrack:
- Better behavior when a lot of channels are loaded.
and several bug fixes, enhancements, etc...
If you appreciate the software, please consider making donations.
Enjoy.
Nicolas BATS
13 years 7 months ago #5916 by Jefff
Replied by Jefff on topic 3.0.13
J'ai un pb avec les commandes SysEx midi :
quand on clique sur connect :
SysEx identifié en play devient SysEx Stop
SysEx identifié en rewind devient Record (launch In)
Ce qui a pour résultat de ne pas fonctionner.
13 years 7 months ago #5917 by Jefff
Je viens de vérifier sur la dernière beta c'est pareil. En tout cas c'est super ce temps en 0.01 ! Ça a l'air beaucoup plus précis !
13 years 7 months ago #5918 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.13
putain :angry:
je suis bon pour une 14
13 years 7 months ago #5919 by Jefff
Nan... Vire-la discrètement puis l'air de rien tu la remets... ;-)
13 years 7 months ago #5920 by sl1200mk2
et dire que c'est déjà corrigé...
mais là 3 mails par jour, les gens vont péter les plombs...
en tout cas si t'en as d'autres comme ça, hésites pas...
je vais voir si je peux mettre la 14 en ligne demain, mais c'est pas sur, sinon jeudi.
13 years 7 months ago #5922 by colinc
Replied by colinc on topic 3.0.13
Hi Nico,
Same problem with 3.0.13 as with 3.0.12
The following user(s) said Thank You: paucurses
13 years 7 months ago #5923 by bgoubert
Replied by bgoubert on topic 3.0.13
salut Nico,
Je commence les test de la nouvelle mouture ,13.
1° truc sous OSC la syntaxe pour ouvrir la fenêtre de check /checkcirc/launch ne l'ouvre que fugitivement. Elle redisparait aussitôt dès qu'on lache le bouton.
Sinon pour l'instant ouverture normale de copies d'anciennes conduites.
A suivre.
Mac os 10.7.5 Iphone, touch osc.
13 years 7 months ago #5926 by paucurses
Replied by paucurses on topic 3.0.13
Hello
I have a question regarding the new d: light (.13 version) ... The shows recorded in past versions are supported? I do not show load?
You can make donations apartir PayPal?
Thanks for this great work! ;)
13 years 7 months ago #5927 by paucurses
Hello
One of the mistakes that we want to create a new woman when is this show ..!
Mar. 19, 2013 07:44:12
Document not parsed successfully.
Recover XML doc did not work.
I will not let me upload past shows ... What hapen?!
I hope to answer ... Thank you!
13 years 7 months ago #5928 by paucurses
Hello
To me it's the same problem .. How can solocionar? What happens in reality?
Thank you!
13 years 7 months ago #5929 by DBO Olivier IRTHUM
Replied by DBO Olivier IRTHUM on topic 3.0.13
Hello Nicolas,
Je viens d'essayer un nouveau fichier avec la dernière release 3.0.13 de D::Light.
Sous Mac osx 10.7
Apparement en shiftlock les touches :
é( pour 2)
è(pour 7)
ç(pour 9)
à(pour 0)
Ne fonctionnent pas.
Voilà pour info je sais pas si c'est un petit bug ou bien.
But if it can help!!
Bye
13 years 7 months ago #5930 by sl1200mk2
@Colin,
can you please post your sho.
it's strange because I've made some tests to fix the bug....
thanx
13 years 7 months ago #5932 by sl1200mk2
@bgoubert,
fais gaffe à ce que ta commande ne renvoie pas 0 quand tu relache le bouton
@PauCurses
maybe there's still a mistake with 13 as Colin pointed out
@Olivier,
avec un nouveau fichier, tu dois pas être obligé de te mettre en CapsLock (Shiftlock, je sais pas ce que c'est...) pour accéder aux chiffres.
si tu tapes directement & par example tu devrais pouvoir accéder au 1.
c'est pas le cas?
13 years 7 months ago - 13 years 7 months ago #5937 by sl1200mk2
@Colin,
would you mind hacking a little bit....
in the file called DLight.tcl in the /bin directory, at the very end you will find that code
Code:
proc myHomeEnv {} { return [list $::env(HOME)] }
can you try 2 things, first remove some part of the code to looks like that
Code:
proc myHomeEnv {} { return $::env(HOME) }
and relaunch DL and try to open a sho
if it's not enough, can you try like that
Code:
proc myHomeEnv {} { return $env(HOME) }
if it works, can you try like that
Code:
proc myHomeEnv {} { return [list $env(HOME)] }
thanx
Last edit: 13 years 7 months ago by sl1200mk2.
Time to create page: 0.197 seconds
