ArtNet problems
1 year 8 months ago #28264 by NachoL
ArtNet problems was created by NachoL
I can't get ArtNet working with DLight, I Have two Nodes and none is working, Computer (macOSX) recognizes the Lan, DLight recognizes the IP but the universes doesn't show. I think is something about the Mask but I just can not get it. Could Someone help me configuring this? Shall I upload pictures or a video of my set-up and steps I make Here?
Thanx a Lot, I have a gig in Germany and I need 4 Universes but I can not Afford to buy a new node, I really would appreciate if I can make this ones work
1 year 8 months ago #28265 by sl1200mk2
Replied by sl1200mk2 on topic ArtNet problems
Hi,
in Artnet, the network card of your computer needs to be in the same IP area of the nodes.
generally node are set as 2.0.0.1, 2.0.0.2 etc... with a netmask like 255.0.0.0
so you need to configure your card as 2.0.0.100 (another IP) and a netmask like  255.0.0.0
once it's done in the setup/artnet, in the output part you select the network card of your computer and click on 'who's online'.
each present node should respond.
1 year 8 months ago #28268 by NachoL
Replied by NachoL on topic ArtNet problems
I share two screen captures. The Node shows as connected, Nodes IP is 2.0.0.101. I setup 2.0.0.102 in net preferences and the subtask 255.0.0.0. The IP appears in DLight, but when I check who's online nothing is happening. Same beaheviour with two different ArtNet node hardware
1 year 8 months ago #28270 by sl1200mk2
What kind of node is it?
of you know for sure that the IP is 2.0.0.101, just write it in the manual registration and click on 'add'
1 year 8 months ago #28272 by NachoL
yes, I also tried the 101, when I write 101 this banner shows up, saying that another web device is using this IP
1 year 8 months ago #28273 by sl1200mk2
Not here... at the bottom of the artnet's setup page of DL
1 year 8 months ago #28275 by NachoL
this is a home made Device made by a very good technician. It's tested and working in several computers wit Grand MA and Avolites
I also tried the Showtec NET-8/5 with the same results
1 year 8 months ago #28276 by NachoL
yes, I tried that, but nodes are still not showing
1 year 8 months ago #28277 by sl1200mk2
In my opinion it's a mistake of the nodes to not respond an artPoll reply to the caller....
Your last picture is OK, click then on available and you should be able to use it.
1 year 8 months ago #28278 by aroom
Replied by aroom on topic ArtNet problems
if you are on macOS sequoia make sure that the Privacy > Local Network toggle is on for DLight
if it's on toggle it off and on again
1 year 8 months ago #28279 by NachoL
Ok, thanx a lot. I'll Try it!
1 year 8 months ago - 1 year 8 months ago #28280 by aroom
I'm not sure it's gonna help, but a dev from QLab told me that some people were having issue with this...
Last edit: 1 year 8 months ago by aroom.
1 year 8 months ago #28281 by NachoL
Just universe 1 is working, The other 3 don't
1 year 8 months ago #28282 by NachoL
Thanx, hope to find a solution
1 year 8 months ago #28283 by sl1200mk2
in setUp/dmxUtility, you need to tell how many universe you want to work with.
tell me if it's ok (an please post a picture of your hand made node)
Time to create page: 0.177 seconds
