- Thank you received: 1075
Anchor mechanism in OSC doesn't seem to work
7 years 3 weeks ago #18965
Replied by sl1200mk2 on topic Anchor mechanism in OSC doesn't seem to work
So... I've tried on the PC and obviously it does not work.
I'll be able to fix it then.
Thanks for reporting.
7 years 2 weeks ago #18981
Hi,
4.1.04_b5 is online and should fix either sub and channel's OSC control.
at least tell me if it works for you.
I've also fix the /pad/enter 1 message but in your example I didn't succed to make the message to behave on focused exit button (aka Ok or Cancel).
so I've used /pad/clear 1 for Cancel and /pad/enter 1 for Ok
thank you for testing,
- stebian
7 years 2 weeks ago #18985
by stebian
stephan
Replied by stebian on topic Anchor mechanism in OSC doesn't seem to work
Hi Nicolas,
reSync does work as expected now. So does /pad/enter 1 in my example! I still use /pad/errorACKNO 1 for Cancel, which works fine for me. I didn't try /pad/clear 1 tonight. Will do tomorrow. But everything seems to be working for me now.
Thanks a lot!!!
Thanks a lot!!!
stephan
7 years 2 weeks ago #18986
cool !!
thank you for the report.
