Anchor mechanism in OSC doesn't seem to work
- stebian
Another question:
I want to make the Enter button work via OSC but /pad/enter 1 seems to be not global enough to validate a popup window in DL. /pad/errorACKYES 1 does the trick. But when I'm asked to enter a group name and I use /pad/ACKYES 1 again, it deletes the group. It all works with the ENTER button on my laptop so I tried to make /shortcut return work but it doesn't. What would be the OSC message for that?
Thanks a lot!
stephan
- Thank you received: 1075
it's done for b5Can you make it work for submasters as well? Because I use the same faders as submasters...
as for /pad/enter 1,
I tested here and it seems to work as expected... When I create a group in DL, it asks for name and options, if I send /pad/enter 1, the group is created.
where or when it does not work for you?
- stebian
Thank you! Have a look at this library github.com/CNMAT/OSC
stephan
- stebian
It does work to record a group. It doesn't if the group was created before and DL asks whether to overwrite the group or not.
stephan
form the main window or from the groupEditor?It does work to record a group. It doesn't if the group was created before and DL asks whether to overwrite the group or not.
- stebian
Similar to this is /pad/clear 1, which twice pressed doesn't work to deselect previously selected channels like BackSpace does. I would just use /shortcut BackSpace, but I couldn't get that one working.
stephan
- stebian
main window
stephan
how do you ask for a group to be overwritten? is it from the shortcut or do you have an OSC sequence for that?
- stebian
I used the shortcut via OSC option a lot (for example numbers) even though there is another way because they act in other windows as well.
stephan
- stebian
stephan
if you hit Enter from the physical keyboard of the computer, does it works?
- stebian
stephan
tomorrow I go on tour till wednesday.
- stebian
Thank you Nicolas!
stephan
