Mac osx 10.7.2, usb DMX Pro, not working!!
il y a 14 ans 9 mois #3911 par blixlab
Réponse de blixlab sur le sujet Re: Mac osx 10.7.2, usb DMX Pro, not working!!
hi yes i have the same setup, it doesnt always fire, sometimes it just makes the go button red and the dimmers go to about 7% by them selves without firing a cue and DL crashes.
The only immediate fire through MSC is to trigger cue 0. when it does work it takes 7 seconds to fire cues regardless of the fade time.
Unfortunately i needed this for a new small show next week (Only 4 chanels and switching between only 3 cues) and have been messing around with it for a long time now as well as the expense of the usb dmx pro. and now i might have to do it with all lights on as i have no operator.
I used lanbox and qlab for a long time and also in main venues i use lanbox and applescript to fire main lighting consoles through ethernet, but as my lanbox LCM doesn't work with 10.7 i decided to bite the bullet and switch to DL based on online reviews. unfortunately it just doesn't seem to work for me.
il y a 14 ans 9 mois #3913 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re: Mac osx 10.7.2, usb DMX Pro, not working!!
you can find the crash report with /Applications/Utility/Console.
can you please send it to me?
does your IAC config looks like attached pict ?
also, can you post your DL .sho to have a look ?
il y a 14 ans 9 mois #3915 par blixlab
21/01/2012 14:15:06.850 com.apple.usbmuxd: _SendAttachNotification (thread 0x7fff7662c960): sending attach for device 04:1e:64:03:20:76@fe80::61e:64ff:fe03:2076._apple-mobdev._tcp.local.: _GetAddrInfoReplyReceivedCallback matched.
21/01/2012 14:15:07.174 usbmuxd: _AMDeviceConnectByAddressAndPort (thread 0x100781000): IPv4
21/01/2012 14:15:30.061 com.apple.usbmuxd: _SendDetachNotification (thread 0x7fff7662c960): sending detach for device 04:1e:64:03:20:76@fe80::61e:64ff:fe03:2076._apple-mobdev._tcp.local.: _BrowseReplyReceivedCallback got bonjour removal.
il y a 14 ans 9 mois #3916 par sl1200mk2
in fact, here's the path of the crash report
/Users/nico/Library/Logs/DiagnosticReports/DLight_2012-01-20-153212_brouhaha.crash
and it must be something like that
Temps de génération de la page : 0.132 secondes
