Mac osx 10.7.2, usb DMX Pro, not working!!
il y a 14 ans 9 mois #3812 par blixlab
Réponse de blixlab sur le sujet Re: Mac osx 10.7.2, usb DMX Pro, not working!!
oh oh, i did exactly as you said, it asked me to replace the file DLight inside the resources folder so i said yes, now it will not run at all...
il y a 14 ans 9 mois #3813 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re: Mac osx 10.7.2, usb DMX Pro, not working!!
yep, sorry, try with this one
il y a 14 ans 9 mois #3814 par blixlab
YES!!!!! It connects!
il y a 14 ans 9 mois #3815 par blixlab
and seems to be running my dimmers fine so far.
il y a 14 ans 9 mois #3816 par sl1200mk2
cool, very cool ;-)
thank you for your patience....
keep that config because i don't know yet how i can manage to get it working in a normal way...
the problem i'm facing is i don't want to remove from your computer ftdi drivers because other hardware can use them... in the other hand, i didn't see anybody in lighting people that use them except for usbPro utility...
i'll try to find a way to unload ftdi driver without the applescript that obviously seems to not working.
hope you'll enjoy DL, and please be aware of testing new beta release when they come out.
il y a 14 ans 9 mois #3817 par blixlab
Thanks so much for your time. i really needed this software to work! next step MSC and qlab and hopefully ill have my new show on the road soon! Thank you again.
il y a 14 ans 9 mois #3818 par sl1200mk2
Colin and flk (aka Freddy) also works this way (DL+Qlab).
i believe there's a thread on the forum called 'Message Show Control' or 'midi Show Control' about that.
il y a 14 ans 9 mois #3827 par sl1200mk2
there's another thing i would like to try with you before messing up everything.
attached zip contain script file i normaly use to unload ftdi drivers. my guess is distributed ones does not have the proper permissions for execution.
so, can you download again the 3.0.7_b10 installer, open it and copy DL not to /Applications (where i guess you've put the working one) but to the desktop.
make sure ftdi drivers are loaded
sudo kextload /System/Library/Extensions/FTDIUSBSerialDriver.kext
unzip attached file and put the scripts in /Desktop/Dlight.app/Contents/Resources
launch DL and try to connect usbPro via libusb.
if my guess is correct, it should ask you for a password to unload ftdi driver and establish connection
il y a 14 ans 9 mois #3875 par blixlab
Hi Nico,
I have tried all of that but the new modified dl doesn't work. it has the same "connecting.." message.
il y a 14 ans 9 mois #3894 par sl1200mk2
hi,
i've just put an installer for 10.7 in download/beta section with a new attempt to unload ftdi drivers.
can you try it (be sure ftdi drivers are loaded!)
thanx
il y a 14 ans 9 mois #3903 par blixlab
hi, it doesnt work... for sure the drivers were loaded.
il y a 14 ans 9 mois #3905 par sl1200mk2
hi,
does DL prompt for a password or not ?
also, here's a zip of only the executable. i would like you to try it with the installer your download yerterday.
put it in /youyesterdayDLight.app/Contents/Resources
and tell me how it goes.
il y a 14 ans 9 mois #3906 par blixlab
Yes this works, it prompts for password and then connects.
One question there is a large delay when triggering cues from Qlab with MSC. is this with all versions or just these?
Thanks
Ronan
il y a 14 ans 9 mois #3908 par blixlab
hi with both these DL versions there is a bug in MSC. whn you fire the Go cue from qlab, in DL the go button goes red and the software freezes up. sometimes it triggers but after a 7 second delay.
il y a 14 ans 9 mois #3909 par sl1200mk2
Ronan,
first, this is a good news about usbPro connection!!
about qlab, i've made some tests with the latest qlab and i didn't observed a major delay (maybe 100ms...)
what is your configuration?
from qlab, i select IAC bus
from dlight i select multiple input
does your configuration is different?
do you notice delay whatever the times of the sequence (i mean is it the same with 0" or 10")?
also, i suggest you to open another thread about that.
best regards,
