- Remerciements reçus 72
4.1.09 dev cycle
- celio
have a nice day
Célio
- Remerciements reçus 1074
me neither I don't succeed to reproduce it...
there should be some steps to reproduce the bug but I don't find them...
@soundsurfer
do you succeed to reproduce it easily?
- SoundSurfer
- Remerciements reçus 3
I tried replicating with a new sho. not possible, but it does with the nabil.sho
here's a video on how it happens:
video link
soundsurfer
did you set a 'theme' on your computer?
in the setup window, the little arrow on attached/detached setting should be blue, not red...
how id you get this?
- SoundSurfer
so that was not the faulty part...
what is your screen resolution ? mine is 15,4 pouces (2880 x 1800) (you can got it from About this Mac / Monitor )
- SoundSurfer
I really don't know why it behave like that on your computer...
for the next beta, I'll allow the resizing of the main window in attached mode. you'll tell then how it goes.
cf Nabil.sho from soundsurfer, en @mode quand on fait Cmd+Q, DL inscrit [CUE] dans la ligne de commande... il ne devrait pas...
- celio
Bonne journée.
Célio.
-Park:
is now registered with the sho
-Palette:
you can now use floating numbers for Palettes (2.1 or 2.05 for exemple)
@Celio
les MLinks doivent controler les sub en Toggle.
Par rapport à ta demande et l'OSC, je ne pense pas pouvoir sortir un /subStick/x/level lors de l'appui sur Toggle, au mieux un nouveau message mais pas celui là...
@soundsurfer
you should be able to resize the main window when display is 'attached'
merci de vos retours,
- celio
- SoundSurfer
On mac Catalina;
I make the window attached, and then full screen, everything is great.
I really like the feature that the patching window that i open with cmd+p opens as a tab!
w:woohoo: w:woohoo: w:woohoo:
THANK YOU!
SoundSurfer
