- Remerciements reçus 1074
4.0.0_b14
- nomatter
Windows drawing is slow and scattered.
Never seen before.
Anyway program seems to work.
Now I'm running XQuartz 2.7.7 and my Mac is not slow or old.
Thanks,
Carlo.
I compile DL on 10.10 thanx to a virtualization of the OS.
on the virtualization, DL is very very laggish... at boot, main window is drawing each sub by each sub, it takes a while.... it's unusable....
but I thought it was a virtualization issue.
do you run 10.10 native on your mac?
- Jefff
- Remerciements reçus 7
- Jefff
- nomatter
sl1200mk2 écrit: Hi Carlo,
I run 10.10 native. (I had to update as soon as possible, don't ask. Grrr.)
It takes not so much time to launch, about 9s since when I start my shell script (it doesn't run without it).
The program works as always. Still drawing process at the launch is "sub by sub", I can see them. Later don't. It's true they're there, so no need to redraw.
It's definitely usable.
I'm using it in rehearsal stage.
Maybe it's just Xquartz, waiting for an update.
A new thing: if I plug a midi controller (NanoKontrol) while it's running, then refresh midi sources and activate it... everything seems to be ok. Control changes faders rise up subs value but they don't pull down. I had to restart DL and than It works again.
It happened two times, tomorrow I will try to recreate it.
Carlo.
maybe... we should ask XQuartz crew for an update....Maybe it's just Xquartz, waiting for an update.
please post results of your tests in order to identify the issue...A new thing: if I plug a midi controller (NanoKontrol) while it's running, then refresh midi sources and activate it... everything seems to be ok. Control changes faders rise up subs value but they don't pull down. I had to restart DL and than It works again.
- nomatter
sl1200mk2 écrit:
So...
Midi controller issue...
Midi controller unplugged / run dlight / load a show with midi plugin saved as active / plug midi control / Refresh Midi (controller is already active) -> control changes work to raise values but not to decrease them
If I create a new show, plug the midi controller and activate it for the first time it works properly.
If I'm running a show, unplug then replug it, DL doesn't work anymore.
In any case, I have to restart Dlight (not just reload the show) to do it works again.
That's it.
Could be a problem if, during a performance, it happens to unplug.
New bug or issue or something I didn't notice.
I'm on cue N in X1 and I change some values: if don't want to save it but to restore smoothly previous version I think I could load N in X2 than crossfade between the two... On the contrary when I load N on X2, output cut to saved one.
Crossfading leads to unpredictable results.
Thanks for your job,
Carlo.
- Tibo T
Par contre, dans le Device Listing, la fonction "Clone device model" ne fonctionne pas. Lorsque je clique dessus, rien ne se passe. Bug ?
Peut être que c'est que cette fonction n'est pas encore développée, mais dans ce cas là, y'a-t-il possibilité d'importer en une fois plusieurs exemplaire d'un même modèles de device ou faut-il importer autant de fois un modèle que le nombre de device utilisés ? par exemple j'ai 20 par led que je veux adresser à 20 channels différents, faut-il que j'importe 20 fois mon modèle par led ?
Merci d'avance !
Tibo
thanx for the test about midi, I'll investigate.
for X2 loading, you're right, there's something wrong.. I'll fix it.
can you elaborate on: Crossfading leads to unpredictable results.
@Tibo
la fonction n'est pas encore écrite... :whistle:Par contre, dans le Device Listing, la fonction "Clone device model" ne fonctionne pas. Lorsque je clique dessus, rien ne se passe. Bug ?
je pense que je vais l'écrire comme ça:
tu importes un Device
tu inscris 20 puis Clone.
DL va te proposer de cloner à la suite des circuits du Device référent, idem pour les gradas et va te demander si tu veux y inscrire un offset de grada (cad, tous les 50 addresses par exemple)
mais pour l'instant, c'est à la mano que tu dois les importer.
peux-tu me dire comme DL se comporte avec tes 20 pars?
les palettes?
les transferts?
la conduite?
- Jefff
Il y a peut-être un problème au passage d'un cue à l'autre :
quand j'ai un WAIT sur un cue et que je fais un GO pendant le décompte du WAIT, si des circuits sont censés baisser du cue précédent à celui où il y a le wait, ils montent jusqu'à FF puis repartent de 0 à FF en boucle. Par contre si tous les circuits doivent monter, pas de problème, le wait est zappé et la montée programmée se passe bien.
Merci pour ton travail.
Jef
- Jefff
Pas de pb quand le WAIT est inférieur à 1mn
Pas de pb quand on appuie sur GO avant que le WAIT passe en dessous de 1mn
Pb quand on fait GO si le WAIT est passé en dessous d'1mn : les circuits qui sont censés descendre font des boucles de 0 à FF, le WAIT est figé, tant qu'on ne fait rien ça tourne en boucle.
- Tibo T
Alors en vérité ce n'est pas avec des Par led mais des récepteurs pour Bande à led mais qui sont tout comme des par à led.Chaque récepteur a une fonction dim (1) / strob (2) et color (3 : Red / 4 : Green / 5 Blue)
Et le projet est plus ambitieux que 20 puisque l'idée serait d'en faire tourner au total prés de 150 sur 2 univers DMX.
J'ai aujourd'hui commencé des test avec 1 seul récepteur sur donc un seul univers.
A priori au niveau des transferts, ça se passe bien. J'ai pas rencontré les problèmes de wait expliqué dans les posts précédents, mais je n'en avais jamais qui dépassaient 30s.
Par contre, je suis repartis d'une conduite écrite sous D:light 3 parce que ça m'évitait de refaire la config du setup (adresse ip, etc,). Cette conduite est presque vierge mais contient 5 mémoires qui ont des wait, des times, et pas grand chose de plus. Or à chaque fois que j'arrivais à la cue 3, D:light plantait et se fermait avec un message d'erreur microsoft type : "D light a rencontré un problème et a fermé".
aprés 3 essais ,j'ai supprimé mes cues et je les ai re-écrites, et là, plus de problème. JE vois donc pas trop pourquoi mais il semble qu'il y'avait un bug en tout cas.
Sinon niveau Device et palette :
première chose, j'ai pas trouvé le module de control effect. En effet le deuxième paramètre de mes récepteurs étant un strob, je l'ai mis en effect / strob dans mon modèle, mais je ne vois pas par où est-ce que je peux le piloter.
et sinon, au niveau des couleurs, pas grand chose à dire sinon que lorsque je me sers des palettes pré-enregistrées, les couleurs qui apparaissent sont parfois très éloignées de ce qu'elles devraient être...
voilou, merci encore pour tout le boulot!
et bien à priori ce type de matos devrait fonctionner (peux-tu d'ailleurs poster la personality que tu as écrite pour ce Device?)Alors en vérité ce n'est pas avec des Par led mais des récepteurs pour Bande à led mais qui sont tout comme des par à led.Chaque récepteur a une fonction dim (1) / strob (2) et color (3 : Red / 4 : Green / 5 Blue)
et si t'en as 150, il doit te tarder que le Clone soit codé....
peux-tu poster la conduite dans l'état, celle qui fait planter DL4?Par contre, je suis repartis d'une conduite écrite sous D:light 3 parce que ça m'évitait de refaire la config du setup (adresse ip, etc,). Cette conduite est presque vierge mais contient 5 mémoires qui ont des wait, des times, et pas grand chose de plus. Or à chaque fois que j'arrivais à la cue 3, D:light plantait et se fermait avec un message d'erreur microsoft type : "D light a rencontré un problème et a fermé".
non, seul les couteaux, positions, couleurs et fonctions d'allumage sont écrits...première chose, j'ai pas trouvé le module de control effect. En effet le deuxième paramètre de mes récepteurs étant un strob, je l'ai mis en effect / strob dans mon modèle, mais je ne vois pas par où est-ce que je peux le piloter.
manque les effets, gobo, etc...
est-ce que tu penses que c'est un défaut de DL ou dû au type de matériel que tu utilises?et sinon, au niveau des couleurs, pas grand chose à dire sinon que lorsque je me sers des palettes pré-enregistrées, les couleurs qui apparaissent sont parfois très éloignées de ce qu'elles devraient être...
merci de tes retours.
