3.0.15_b5
il y a 13 ans 6 mois #6194 par sl1200mk2
3.0.15_b5 a été créé par sl1200mk2
what I *need* to know with this one is if it starts/run well on linux 32/64 systems, as well as on MacOS 10.5 systems.
it should correct wrong behaviors.
just a quick news, in the midi window, when you use the 'recycle' function to load Midi part, DL should point to the corresponding connection if it exists.
Thank you for reporting!
Nico
il y a 13 ans 6 mois - il y a 13 ans 6 mois #6200 par colinc
Réponse de colinc sur le sujet 3.0.15_b5
Hi Nico
Installed 3.0.15_b5
sl1200mk2 écrit: 3.0.15_b5 is online.
@Colin
several tentative with new libusb-1.0.dll are all successfull on different machines.
each time, zadig ask me to replace drivers from FTDIUSB to WINUSB, and after a reboot, I can access to ultraDMX Micro.
so the 3.0.15_b5 include the new libusb.
merci de répondre dans le thread de la 3.0.15_b5
Ok, so I...
1) Control Panel -> Device Manager -> Universal Serial Bus Devices -> USB Serial Converter -> Uninstall Driver -> Disconnect DMXMicro
2) Reconnect DMXMicro -> Windows reinstalls FTDIBUS driver (Check it's connected by running eg QLight Controller
3)Run Zadig.exe (Latest version 2.0.1.160), and re-install WinUSB (v6.1.7600.16385)(libusbx)
4) Reboot
5) Run DLight - 'USBDMX not found' - clicking red light doesn't connect - also, the 'progress' window in dlight (top right) says 'libusb_open() failed'
6) Select ArtNet instead of USB - artnet discovers eg iPad ok, etc
7) Reselect USBDMX - 'not found, and no connection
8) Replace again with libusb-1.0.ddl from 3.0.15_b3 and 'Bingo', DMXMicro connected...
:S :(
il y a 13 ans 6 mois #6202 par pancho
Réponse de pancho sur le sujet 3.0.15_b5
démarre bien sur mon linux 64b.
J'ai passé une conduite sans souci,
la led du boitier clignote (pas de grada sous la main)
je rapporte si problème
il y a 13 ans 6 mois #6204 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.15_b5
@Colin,
attached a libusb-1.0.dll
can you please unzip it, copy it in the bin folder and try again.
this is odd,
why do you let windows reinstall drivers?
Nico
il y a 13 ans 6 mois #6205 par sl1200mk2
@pancho,
merci d'avoir été si prompt aux tests ;-)
il y a 13 ans 6 mois #6209 par Barrillet
Réponse de Barrillet sur le sujet 3.0.15_b5
Pour le MIDI :
Désolé mais pas d'améliorations notables, en changeant ma conduite son sous Ableton Live je réussi a faire a peu près ce que je veux par contre :)
Merci d'avoir bossé dessus, mais ça a l'air un peu compliqué non? :blink:
il y a 13 ans 6 mois #6210 par sl1200mk2
@Padbol,
ça veut dire qu'à 10ms dès que ton sub passe par 0 il ne remonte pas après?
ouais c'est balaise....
il y a 13 ans 6 mois #6211 par Barrillet
Mouais bon, en fait c'est bizarement compliqué, parfois ça marche, parfois ça marche pas.
J'ai trois sub qui s'enchainent, en MIDI controlées pas Ableton Live. J'ai modifié les courbes MIDI pour avoir une montée treees progressive et assez lente. Parfois le signale est bien pris en compte, parfois non...
il y a 13 ans 6 mois #6212 par sl1200mk2
et ça, ça devrait pas....
ça devrait être une horloge....
à quelle vitesse t'arrive à avoir des bons résultats?
ça à rien à voir avec l'alarme dont tu parlais si?
parce que ça c'est peut-être le symptôme d'un autre bug...
peux-tu décrire comment tu fais pour 'enchainer' tes trois subs? et à quelle vitesse?
il y a 13 ans 6 mois #6213 par Barrillet
Alors reprenons :
L'alarme c'est bon. Avec tes modifs et les miennes ça remarche (j'ai réduit le nombre d'infos midi)
Pour l'autre : En fait sur une chanson j'ai 5 subs en tout :
2 Subs qui font un "chaser" : Un qui clignote sur les aiguës, un autre sur les bass. Un plugin me transforme le son en info midi.
3 Subs qui s'enchainent a la fin sur une batterie (ambiance One Man Show, désolé...). Chacun des Subs reste 2 secondes en place en gros.
Les 2 premiers fonctionnent bien, les 3 autres ont du mal a s'enchainer. La solution que j'ai trouvé c'est de mettre une jolie courbe sur le midi pour qu'il n'y ai qu'un seul Sub envoyé a la fois. Ca marche, mais du coup c'es compliqué de superposer plusieurs Sub avec cette méthode.
Bref je bosse dessus pour trouver la meilleur méthode, ça devrait finir par marcher, et puis je doute que l'oeil de Madame Michu fasse la difference entre un enchainement de 100ms et 10ms ;)
il y a 13 ans 6 mois #6214 par sl1200mk2
Ahhhh madame Michu.....
est-ce que tu peux re-essayer en remettant les infos Midi à blinde _ en gardant la résolution de 10ms pour voir si ça passe.
donc ce que tu dis c'est que si t'envoies 2 infos midi en même temps (sur le même canal(?) et avec numéro de CC différents j'imagine), DL n'en prends qu'une des deux? t'es donc obligé d'envoyer des infos Midi pour qu'il n'y ait qu'un seul déclenchement à chaque fois.
tu peux joindre un MidiMon de cette commande multiple?
il y a 13 ans 6 mois #6215 par Barrillet
Voila les log de la sirene, sur la chanson c'est un peu plus galere a faire.
2 log : Un qui ne fonctionne pas, trop d'info, l'autre qui fonctionne pile poil (si j'augmente la frequence sur celui ci ça ne fonctionne plus)
La pièce jointe Sirene.zip est absente ou indisponible
il y a 13 ans 6 mois - il y a 13 ans 6 mois #6216 par Barrillet
Pour la chanson :
Tout les subs sont sur le même canal, en fait j'avais un Sub qui ne s'arrêtait jamais il envoyé du coup j'en avais en permanence 2 en route, plus un 3eme au moment des chevauchement. En virant celui ci ça marche.
En résumé : 2 subs en même temps Ok.
3 : Pas boooon
EDIT
Les subs sont sur le même Channel, mais avec des CC différents.
il y a 13 ans 6 mois #6217 par sl1200mk2
pour la sirène:
attends je me suis peut-être gouré dans la lecture du MidiMon...
10:59:52.677 From Bus IAC 1 Control 5 0 1
10:59:52.678 From Bus IAC 1 Control 5 0 0
l'intervalle entre les deux c'est pas 10ms mais 1ms non?
je peux te garantir un fonctionnement à 10ms, mais à 1ms, non.
il y a 13 ans 6 mois #6218 par sl1200mk2
pour la chanson:
c'est quand même con si on peut pas envoyer 3 Subs, non?
mais ça m'étonne....
rephrasons (;-)) pour que ce soit clair:
Live envoie une info Midi a un instant t qui lève un sub. le sub est levé et tourne.
Live envoie une info Midi a un instant t+x qui lève un sub. le sub est levé et tourne, ça fait 2 subs qui tournent.
Live envoie une info Midi a un instant t+y qui lève un sub, et là c'est le drame, le sub ne veut pas se lever.
Temps de génération de la page : 0.212 secondes
