- Remerciements reçus 4
3.0.15_b1
- noelvd
il y a 13 ans 7 mois #6079
par noelvd
Réponse de noelvd sur le sujet 3.0.15_b1
Still no luck
But no we know that it is me, not DL.
I have removed Dl and XQuartz, did a fresh download of both, and re-installed it. Still no luck.
Any suggestions ?
I am thinking of re-installing the system software.
Best regards,
Noel
Any suggestions ?
Best regards,
Noel
- Remerciements reçus 1074
il y a 13 ans 7 mois #6080
Réponse de sl1200mk2 sur le sujet 3.0.15_b1
@JJ
ok, on va faire des tests dans ce sens.
@pancho,
tu tombes pile poil à l'endroit que je voulais tester.
est-ce que le niveaux des circuits est aussi erroné quand tu n'est pas en affichage 'Only Used Channel'?
@Noel
there still can be a difference if your macMini is in 32bits and pancho's computer is in 64bits
@pancho,
@Noel
- noelvd
il y a 13 ans 7 mois #6082
@Noel,
attached a zip that contain 2 libraries.
would you mind trying to copy them in the DLight.app/Contents/MacOs instead of existing ones and try to launch DL?
you unzip the archive.
you 'Ctrl+Click' on DL icon, you move to Contents/MacOS and you copy the two dylib (libnettle.4.5.dylib and libhogweed.2.3.dylib)
you relaunch DL and it works
Les utilisateur(s) suivant ont remercié: noelvd
- noelvd
il y a 13 ans 7 mois #6084
Nice
thank you for reporting that.
today I've to do some drawing stuff, I need to figure out Pancho && JJ's issue and I will update a b3 with those libraries.
(maybe tomorrow or next week)
Nico
Nico
- noelvd
il y a 13 ans 7 mois #6087
par noelvd
Did a few quick tests, all of which worked flawless
- Connected iPod (TouchOSC), and verified 2-way communication.
- Imported .asc file (only the Title did not import correctly, but that is a minor issue. Will need to check that again)
- Changed (background) colours
- Saved .sho
- Changed circuit view from 'all' to 'used only', and back (a few times, at different stages)
Will test more tonight and in the next few days.
(discovered that I find the dark blue [submaster levels] on the black background [in the 'circuits' window] hard to read. Could be my old eyes...)
Best regards,
Noel
- Saved .sho
Best regards,
Noel
- noelvd
- pancho
- Remerciements reçus 12
il y a 13 ans 7 mois #6090
par pancho
Réponse de pancho sur le sujet 3.0.15_b1
te joint mon patch puredata
un petit patch de débutant pas commenté et sans doute bancale : je ne garanti pas que le problème ne vienne pas de lui...
il permet d'envoyer la valeur du slider de droite à tous le circuits correspondants aux cases cochées, avec un possibilité de sélectionner une ligne ou une colonne out tout ou rien ou inverser, et de scroller ce qui est allumé dans les 4 directions.
les circuits sont affectés en midi channel 5, de 1 à 80
j'ai aussi essayé sur la 3.0.7 sans souci
- pancho
- cachuette
Temps de génération de la page : 0.212 secondes
