3.0.15_b1
il y a 13 ans 7 mois #6056 par sl1200mk2
3.0.15_b1 a été créé par sl1200mk2
Hi,
this is a big deep step in internal code for moving Heads/Leds integration.
so please test it heavily and please report.
you can also test wrong behaviors of the 3.0.14
Nico
il y a 13 ans 7 mois #6064 par noelvd
Réponse de noelvd sur le sujet 3.0.15_b1
Can't get 3.0.15_b1 to run on my Mac Mini with 10.6.8
Can anyone else try and see if it runs on 10.6 ?
Thanks !
Noel
B)
il y a 13 ans 7 mois #6065 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.15_b1
can you confirm the complain of the system when you execute the command line:
il y a 13 ans 7 mois #6066 par noelvd
It says:
bash-3.2$ /Applications/DLight.app/Contents/resources/DLight
dyld: Library not loaded: /Users/nico/daylight/lib/nettle-2.6/install-i386/lib/libnettle.4.dylib
Referenced from: /Applications/DLight.app/Contents/resources/../MacOS/libhogweed.2.3.dylib
Reason: image not found
Trace/BPT trap
Thanks !
Noel
B)
il y a 13 ans 7 mois #6067 par sl1200mk2
this is very odd
can you please install this quicklook plugin
macdylibbundler.sourceforge.net/
you pick the CaptainMacLib v0.1
you download/unzip/move the plugin into this place
YourComputer/Library/Quicklook
now you right clic (or ctrl+click) on the DL icon (in /Applications) and you choose the option 'Display bundle contents' (it might be other thing as I don't know what it says in english)
you move to Contents/MacOS
and you select the libhogweed.2.3.dylib and hit the space bar.
(thus the previously installed quicklook plugin will tell us the dependency of DL.)
and you should see something like that
/Applications/DLight.app/Contents/MacOS/libhogweed.2.3.dylib
/Applications/DLight.app/Contents/MacOS/libhogweed.2.3.dylib:
@executable_path/../MacOS/libhogweed.2.3.dylib (compatibility version 2.0.0, current version 2.3.0)
@executable_path/../MacOS/libnettle.4.5.dylib (compatibility version 4.0.0, current version 4.5.0)
@executable_path/../MacOS/libgmp.10.dylib (compatibility version 12.0.0, current version 12.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 159.1.0)
thanx
il y a 13 ans 7 mois #6068 par noelvd
Tried that, but I don't see those lines.
Maybe I made a mistake somewhere...
Noel
B)
il y a 13 ans 7 mois #6069 par sl1200mk2
well we will try another way...
I'll recompile libs in a different style and post a b2.
will tell you when it'll be ready
il y a 13 ans 7 mois #6070 par noelvd
Merci, Nico :)
Obviously, I'm am not a programmer, but I noticed that DL seems to be looking for a file that is not there:
Of course, there is no user 'nico' on my Mac, so DL can not find the file.
Are am I telling nonsense now ?...
Best regards,
Noël
B)
il y a 13 ans 7 mois #6071 par sl1200mk2
nope, that's correct
il y a 13 ans 7 mois #6072 par sl1200mk2
Noel,
I've uploaded a b2, would you mind trying it?
il y a 13 ans 7 mois #6073 par noelvd
Encore merci, Nico :)
Will test tomorrow morning .
Don't have access to the Mac Mini tonight.
Best regards,
Noël
B)
il y a 13 ans 7 mois #6075 par pancho
Réponse de pancho sur le sujet 3.0.15_b1
la b2 fonctionne chez moi mac 10.6.8,
j'ai défilé qqs conduites, tout à l'air de fonctionner,
plus de tests à suivre, notemment midi.
belle soirée à tous
il y a 13 ans 7 mois #6076 par sl1200mk2
@Pancho
et avec la 3.0.14 avec la ligne de commande, ça faisait pareil que Noel?
il y a 13 ans 7 mois - il y a 13 ans 7 mois #6077 par cachuette
Réponse de cachuette sur le sujet 3.0.15_b1
@nico j ai testé la nouvelle version sous xp et seven 32 bit avec enttec artnet plus bsf 2000 tout est ok sauf juste au niveau midi ¢a ma fait pareil avec la 3 12 b8 .j avais pas teste la 3 13 et la 3 14 dans la meme config. en fait sur la bsf je perds tout mes potards rotatif donc il faut que je reprogramme après c est ok . ce qui est bizarre c est que les affectations sont bien présente mais non active même en ra pellant ma sauvegarde xml ¢a ne marchait pas .
voila voila aller a plus
JJ
juste une petite précision j'avais fait quatre pages de midi switch et c’était pareil sur les 4 les touches de flahs et les potard linéaires c'etait bon mais pas les rotatifs apres réaffectation touti va béné
il y a 13 ans 7 mois #6078 par pancho
@nico
la .14 démarre nickel chez moi, du bureau et en ligne de commande aussi..
j'avais aussi une mise a jour de xquartz qui aurait pu jouer mais ça marche tout aussi bien avant la maj qu’après...
sinon, le midi se comporte étrangement avec la 15b2, alors que tout fonctionne nickel avec la ...11b10 (j'ai pas le temps de toute les télécharger et tester, ça va trop vite...)
après j'ai une config un peu space... pour résumer, j'ai un patch puredata pour contrôler un mur de 80 lampes (8 par 10) qui envoi 80 valeurs midi (différentes ou non de zéro) qd je bouge dans pure data. je fais des lignes par exemple et dlight, ds la version 11b10 suivait mes valeurs, full pour 10, que je peux décaller à droite ou à gauche. Dans la version 15b2, (en vision only used chanels) la première ligne est a full, puis qd je décalle, il me donne les bons circuits, ceux de la ligne 'à côté, mais avec 0 comme valeur et cela pour toutes les lignes suivantes...
et tout à l'heure, il me donnait des valeurs exotiques en plus pour les autres lampes, sensées être à zéro...
je continue de tester des trucs ces jours et te dit si il se passe qqchose de plus précis.
Temps de génération de la page : 0.165 secondes
