3.0.12 b6
il y a 13 ans 8 mois - il y a 13 ans 8 mois #5694 par colinc
Réponse de colinc sur le sujet 3.0.12 b6
Hi Nico
sl1200mk2 écrit: @tous,
merci de votre participation
@Colin
If a MIDI out is connected, and subs have MIDI control, the normal operation of that sub is impaired
from what you described and from what I've noticed:
if Midi Out is enabled and MidiIn and Out are set to the same way, there's a loop problem.
DL send to midi out submaster's level. as DMX have twice more value than Midi, as soon as sub level is 1% in DL (in fact 3 dmx value), it's converted to 0 in midi level and sended out.
if there's a midi loop, DL also receive 0 for the sub, and so reset sub's level to 0.
thus, if there's a midi loop, a submaster cannot raise.
does it make sense?
More experiment shows, that where Multiple MIDI Inputs is selected, there are some Output choices which have the MIDI Loop problem, and some don't
MIDI Sources are
Echo AudioFire 4 Firewirewith MIDI In/Out(connected to BCN-44 C0ntroller)
LoopBe Virtual MIDI Cable
MIDIYoke 1 Virtual MIDI Cable
MIDIYoke 2 Virtual MIDI Cable
rtpMIDI Wireless MIDI Connection
TouchOSC Bridge Wireless MIDI Connection
No Loop Problems (ie Subs, Scene Master etc work OK)
Multiple In - Echo AudioFire Out
Multiple In - rtpMIDI Out
Multiple In - TouchOSC Out
Loop Problems (ie Subs, Scene Master etc DO NOT WORK)
Multiple In - LoopBe Virtual Cable Out
Multiple In - MIDIYoke 1 Virtual Cable Out
Multiple In - MIDIYoke 2 Virtual Cable Out
So the problem seems to be inherent in any Virtual Cable, and indeed LoopBe themselves warn of endless feed back with similar connections
But also, because of the nature of the Wireless MIDI applications, the seem to allow INPUT to DLight, but if they are selected as the OUTPUT, then Subs work ok, but can't use the output to allow monitoring (or, presumably, Motorised Faders) :(
So, Vive les CHECK BOXES...!!! Please...!!! B)
il y a 13 ans 8 mois #5696 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.12 b6
will definitely try check boxes for midi.
maybe next week or the week after as I do not have rush any more for 3.0.12
thanx,
Temps de génération de la page : 0.115 secondes
