3.0.5 (Release)
- db-kristian
- sonolivier85
- Remerciements reçus 5
I tried the 3.05 and like the improvements.
There are two problems i think.
There is a problem with the .sho encode to older version.
The que list is exported but there is no dimmer info also no Sequence is encoded.
If i record a sample and assign it to a submaster it is ok, but if i edit the sample the change is not visible in the submaster.
Are you also planning to make .1 steps available in the future?
- Remerciements reçus 1074
when do you have a problem? when you want to encode former show to the new .sho file format or when you want to decode new .sho to the former form?There is a problem with the .sho encode to older version.
ok i'll check thatIf i record a sample and assign it to a submaster it is ok, but if i edit the sample the change is not visible in the submaster.
no, steps will always be +1Are you also planning to make .1 steps available in the future?
but you can create 1000000 cues between 1.0 and 2.0. i think that's enough for many uses
- reno-
- Remerciements reçus 9
- sonolivier85
The Problem is when i want to decode new .sho to the former form
- JoMa
- Remerciements reçus 2
a+
pipou
- sonolivier85
This is on OSX Intel 10.6.7
ok, i'll check that.
i think i've fixed the sample modify issue.
please can you test that particulary with the next 3.0.6 beta release.
- reno-
fabien.wen écrit: Salut. Je n'arrive pas a avoir de retour d'infos circuits ou cue pour savoir quel cue ou circuit est sur scene. Pourriez vous me dire quelle syntax utiliser et avec quelle fonction de osc édit. "label" ou autre. Merci
En fait je suis un gros NAZ je n'avais pas bien reglé le writer OSC.
Merci qd même je m'éclate et me prépare un petit pad perso... Vraiment trop bon cet outil
can you post here, the .sho wich is malformed when you want to decode it?
i've tried with some sho i have and they all decoded fine
thanks
- sonolivier85
the sho you sent me decode fine here.
for example, it produce the joined seq list wich seems to be fine.
i don't know if it's possible to reopen with previous realease of DL a show passed throught 3.0.6_b3...
- sonolivier85
do you have the same conduite.xml file?
does the memory folder is empty?
