dmx usb configuration last version of dlight
il y a 1 an 3 semaines #29289 par Jou Serra Forasté
dmx usb configuration last version of dlight a été créé par Jou Serra Forasté
simple question!
I download the last show of dlight and i connect entenc usb and i dont see its taking dmx And its not working. I have my license and all correct.
Thanks
il y a 1 an 3 semaines #29290 par Kyriane
Réponse de Kyriane sur le sujet dmx usb configuration last version of dlight
hey, si tu es sur windows essaie de mettre a jour tes ports usb avec Zadig
il y a 1 an 3 semaines #29296 par sl1200mk2
Réponse de sl1200mk2 sur le sujet dmx usb configuration last version of dlight
@Jou Serra Forasté,
I would say the same thing, please reinstall drivers thanks to zadig.exe (if it's a PC)
getdlight.com/wiki/index.php/Interfaces_...drivers_pour_USB_PRO
il y a 1 an 2 semaines - il y a 1 an 2 semaines #29347 par Jou Serra Forasté
Réponse de Jou Serra Forasté sur le sujet dmx usb configuration last version of dlight
Hi,
Thank you all for the replies.
Actually I'm using a MacOs so no need for zadig.exe. My enttec DMX Usb Pro is detected and I see it on the top right of Dlight, and everywhere it appears as normal, but the enttec doesn't light up as usual when signal is send there, so my guess it that there is something between those two elements that is not working.
Thanks all for the help!
Jou
il y a 1 an 2 semaines #29348 par sl1200mk2
@Jou Serra Forasté,
can you please post a pict of your usbDMX setting ?
Temps de génération de la page : 0.138 secondes
