Midi Map Tilt-PAN-Zoom moving head
2 years 11 months ago #25919 by NachoL
Midi Map Tilt-PAN-Zoom moving head was created by NachoL
Hola, I wonder if there is a way in DLight to midi map Tilt, Pan and zoom to controller wheels. Can you explain me how to do it?. Is it possible to map it for example to one wheel and works for the selected Head?
Thank You
2 years 11 months ago #25920 by sl1200mk2
Replied by sl1200mk2 on topic Midi Map Tilt-PAN-Zoom moving head
Hi,
yes, patch your wheel to Midi dbWheels.
dbWheels are bounded to columns if the dynamicBottom. Thus if you display FOCUS, first wheel will behave on Pan, second on Tilt. If you display Colours, first wheel will behave on Red, etc...
2 years 11 months ago #25921 by NachoL
Replied by NachoL on topic Midi Map Tilt-PAN-Zoom moving head
Ok, Thank you!
2 years 11 months ago #25922 by NachoL
Ok, it works.
Would it be possible to assign a wheel to a parameter without selecting it in the dynamic bottom. For example a wheel that is always zoom just when selecting the Head?
2 years 11 months ago #25923 by sl1200mk2
Hi,
nope... you'll need to use either a Palette or a microPalette loaded into Sub for that purpose.
2 years 11 months ago #25925 by NachoL
Ok, thanx.
Time to create page: 0.129 seconds
