KORG NANOKONTROL 2?
5 years 1 month ago #21999 by polillin
KORG NANOKONTROL 2? was created by polillin
Hello, I'm planning to buy a Korg Nanokontrol 2 so that I can use it to regulate submasters in Dlight via MIDI. I suppose I could change through more than 8 faders with the substick option and changing pages of submasters. Am I right? Is it difficult to configure in Windows 10? Thanks!
5 years 1 month ago #22000 by aroom
Replied by aroom on topic KORG NANOKONTROL 2?
yes you can use sub stick to switch sub pages and keep the faders mapped.
you'll have to use the soft from Korg to change some button from CC to Note. it's rather easy yes. and then the mapping can be done inside D::Light.
The following user(s) said Thank You: polillin
5 years 4 weeks ago #22052 by polillin
Replied by polillin on topic KORG NANOKONTROL 2?
OK. I have one more trouble. I'd like to change pages and keep each submaster's value. But if I leave, for instance, Submaster 1 at 80% and pass to page 2, if I want to touch the slider 1, it starts Submaster 9 at 80%, not in zero. Anyone understands my problem and can tell me if there's a way to do it? Thanks!
5 years 4 weeks ago #22054 by aroom
have you tried the "Bypass level's anchor mechanism " option?
5 years 4 weeks ago #22055 by polillin
It works!!!! Thank you very much, sir!!!!
