Midi
10 years 10 months ago #11511 by laverda
Midi was created by laverda
Hi i have a problem which midi in my 3.0.24
When i assign a channel to a midi with cc. That channel does not work normally being run from a master or in an FX. The channel will go to a value and stay there until i manually set its value to 0.
Anyone else had this problem? Any solutions?
10 years 10 months ago #11512 by sl1200mk2
Replied by sl1200mk2 on topic Midi
hi
can you please try with the latest beta to see if the problem persist...
10 years 10 months ago #11522 by laverda
Replied by laverda on topic Midi
Hi!
I have tried to get this version to work but i can not open it properly. It only initiates but the program itself does not open. I have a quite old mbp and have not updated osx to more than 10.8.5.
Maybe i should clarify that it is not the midi that does not work, it is only the Masters and the FX that creates channels getting stuck. The seuense and the ques work fine.
However i just discovered that disabling the midi outputs solves the problem :-)
Thank you for your reply
10 years 10 months ago - 10 years 10 months ago #11523 by aroom
Replied by aroom on topic Midi
hi
to use the last beta, you'll need to upgrade xQuatz as well
Last edit: 10 years 10 months ago by aroom.
10 years 10 months ago #11526 by laverda
Hi!
Ok thank you!
i have this version XQuartz 2.7.8 - 2015.10.17. Then there is only a beta version pre-release. Is that the one i need to get?
Thomas
10 years 10 months ago #11527 by aroom
as far as a know you need :
xQuartz 2.7.7 for all the version 3.0.x and 4.0.x until the DL_4.0.0_b50
and
xQuartz 2.7.8 for all the new releases, beginning with the DL_4.0.0_b51
if you struggle when starting the software, you can try to launch it with the terminal with this command :
Code:
or you can try to re-install xQuartz and reboot the computer
Time to create page: 0.137 seconds
