touchOSC hacking 4 Android
14 years 1 month ago #4999 by sl1200mk2
touchOSC hacking 4 Android was created by sl1200mk2
www.circuitbentobox.com/note/how-to-cust...ouchosc-for-android/
if you try this, would you mind report your results....
14 years 1 month ago #5019 by dFVarela
Replied by dFVarela on topic touchOSC hacking 4 Android
My Android just got back from repair, I'll tested as soon as posible, i've got to make a show out of my home place so i'll be using DLight whit a ultraDMX Micro and then report it back to you!
dFVarela
14 years 1 month ago #5020 by dFVarela
It doesn't work :( !
For some reason the Android version of TouchOSC doesn’t support Labels, so if you add them in your layout and use this workaround to load it, your whole layout will just be black and unusable.
I'll have to continue using Control! When a new dlPad.js?
dFVarela
14 years 1 month ago #5021 by sl1200mk2
Replied by sl1200mk2 on topic touchOSC hacking 4 Android
Daniel,
thxx for testing this... it's a shame it does not work...
did you see the one Colin wrote?
i use it and it's good. his dlPad.js reside on the dlight-tools github.
The following user(s) said Thank You: colinc
14 years 1 month ago #5028 by dFVarela
It's a TouchOSC problem....:(
The one under: dlight-pad / control / dlPad.js?
It is the one i'm using but is missing things like 'GoBack', and so on...... But it works, focused everything today with it!
dFVarela
14 years 1 month ago - 14 years 1 month ago #5030 by colinc
Replied by colinc on topic touchOSC hacking 4 Android
dfvarela wrote: It's a TouchOSC problem....:(
My version does have GoBack - and Pause, Blackout, Live (scene) and Blind ( prepas), and a whole separate page with 10 submasters. But it's a fork from Nico's so he will have to pull it, or I will try to attach it here
Attachment Control_dlPadfile_2012-09-14-2.zip not found
Last edit: 14 years 1 month ago by colinc. Reason: Only 10 subs!
14 years 1 month ago #5031 by sl1200mk2
@Colin
any idea of how to merge from your fork ?
14 years 1 month ago #5041 by colinc
@Nico
(see also the other dlPad thread, where I've posted the same)
I have sent you a 'Pull Request' from my GitHub fork. If you go to the 'Help' tab on the GitHub pages, there is a section on 'Pull Requests, and also how you respond to the request, review my fork, and then the commands to issue to merge my fork into your repository.
My fork for the Merge command is 'github.com/colinctoo/dlight-pad'
Regards
Time to create page: 0.246 seconds
