OSC
14 years 6 months ago #4354 by paucurses
OSC was created by paucurses
I'm Pau Carreras and have serious problems with OSC: Not as OSC forms of d:: light with the application CONTROL of "android". I would like to receive simple information to since form it (that to put in every place; OSC reader, OSC writer...)
I Expect to receive information.
Thank you very much!
Hola,
Soy Pau Carreras y tengo serios problemas con el apartado de OSC: No se como configurar el apartado de OSC del d::light con la aplicación CONTROL de “androide “. Me gustaría recibir información sencilla de como configurar-lo (que poner en cada lugar; OSC reader, OSC writer,...)
Espero recibir información.
Muchas gracias!
Je Suis Pau Carreras et ai des problèmes sérieux avec la partie d'OSC : pas comme la partie d'OSC configure de d::light avec l'application LE CONTROL de "androide". J'aimerais recevoir une information simple de comme le configurer (que mettre à chaque lieu; OSC reader, OSC writer...)
J'espère recevoir une information.
Merci beaucoup![/b][/i]
14 years 6 months ago #4355 by sl1200mk2
Replied by sl1200mk2 on topic Re: OSC
OSC Reader is the port where DL receive the information. the IP is the IP of your computer, the port is the one you choose.
on the Control side, in the Destination tab, you have to set this information.
for now, Control only receive information on port 8080, so in the OSC writer of DL, you have to put the IP of your phone and 8080 to the port
14 years 6 months ago #4362 by paucurses
Replied by paucurses on topic Re: OSC
Thank You! Perfect! GReat!
