LS-Node 2 (www.workpro.es)
5 years 10 months ago #21014 by sl1200mk2
LS-Node 2 (www.workpro.es) was created by sl1200mk2
www.workpro.es/products/ls-node2
today I've received this widget from workpro.es and I must say I'm very impressed :)
First, it works very well with D::Light using artNet or sACN protocol.
Then comes the design of the ls-node, the hardware seems robust and beautify with their logo on the top (which looks modern !!).
The power supply is included in the package and the connector is usb-C type (another good point). On the front, 5V,2A is printed (the power consumption). I find that print is very welcome in order to know which power requirement is requested.
Still on the front, 2 ethernet connector for their merger mode (from the manual):
- Merger mode: where the LS-Nodes can receive different universes (via ArtNet/sACN or DMX) and merge them in the same output, being able to select HTP/LTP merge modes.
And it's the first node I know with this ability.
on the rear, 4 DMX port that can be used as Input and Output... nice!!
the configuration of the node is made thanks to a webBrowser, that means no additional software required... excellent!!
so it looks like a damn good node.
The following user(s) said Thank You: zenerve
Time to create page: 0.105 seconds
