Issue with DMX Output
4 years 8 months ago - 4 years 8 months ago #22920 by oscgonfer
Issue with DMX Output was created by oscgonfer
I was using OSX 10.15.7 and D:LIGHT version 4.1.13 (now updated to latest). I am using DMX USB Pro.
License was working fine, although now in latest I have issues activating it and it says I am in DEMO mode.
I have followed all the steps in the Apple Bug issue post and I have not been able go beyond the DEMO mode.
However, the issue is as follows, before and after the update, in some venues (in particular the one I am at), it has happened that I am not able to send clean DMX output.
I have tested with different USB cables, different ENTTEC USB Pro and different computers.
Sending the signal to another desk (DMX IN), we see that the signal is fully noisy and channels are random.
Using DMX-Pro Manager and Lxconsole using the same hardware I had no issue, everything is fine.
Any ideas? I have seen this post in the forum( getdlight.com/forum/dmx-usb/6767-dmxusb-pro-probleme-signal-dmx ) describing the same issue. As of now, I would only like to go back to a previous version (4.0 maybe?) and try out, because I need to make progress in the technical rehearsals we are doing. Important comment: I am unable to continue with other softwares because I am using the StepLINKs from DLIGHT to send OSC messages to other controllers, and the flexibility of DLIGHT in this case is really important for me.
Can you please support?
Thank you,
Óscar
Last edit: 4 years 8 months ago by oscgonfer.
4 years 8 months ago #22921 by sl1200mk2
Replied by sl1200mk2 on topic Issue with DMX Output
Hi Oscar,
This Apple bug is really annoying and set life harder for everyone...
So , if with v4.3.01 you cannot deactivate then activate your key, please send me an email (thanks to the Contact form) and I'll deactivate it.
4 years 8 months ago #22922 by oscgonfer
Replied by oscgonfer on topic Issue with DMX Output
Hi,
So just to confirm, the spurious DMX output is because of the license?
Time to create page: 0.121 seconds
