Re: Mac osx 10.7.2, usb DMX Pro, not working!!
14 years 9 months ago #3917 by blixlab
there bis no DL file there. sometimes i have to trigger the qlab cue 3 times to get it to trigger DL but it still makes the go button red for 7 seconds before triggering the cue.
14 years 9 months ago #3918 by blixlab
also if its any help when it triggers the 0's in DL flicker for the 7 seconds.
14 years 9 months ago #3919 by sl1200mk2
Replied by sl1200mk2 on topic Re: Mac osx 10.7.2, usb DMX Pro, not working!!
did you try to set Device ID to 1 (just in case 0 is a broadcast address)?
14 years 9 months ago #3920 by blixlab
Ha that's It!!!!!! Sorry i should have thought to try that myself!!
14 years 9 months ago #3921 by sl1200mk2
what i do not know is if you found a bug with 0 deviceId or not...
i'll investigate that next week...
can you make another try is to set your dmx output to libusb, and tell me if everything is fine (of course with the last DLight app i sent you and ftdi drivers loaded)
14 years 9 months ago #3922 by blixlab
Ok just relaoaded drivers from installer as i had manually deleted them before.
All is working perfect! I seem to remeber Lanbox having an issue with id 0 also.
14 years 9 months ago #3923 by sl1200mk2
cool!
about lanbox, i think you can use it via artnet....
anyway, thank you for all these tests and please be aware to test 3.0.7_b11 when it'll be online (begin of next week)
14 years 9 months ago #3944 by sl1200mk2
please test 3.0.7_b11 !
14 years 9 months ago #3948 by blixlab
OK have it running nw and all seems good!
14 years 9 months ago #3949 by sl1200mk2
thanx,
as you maybe noticed, i removed midi show control ID 0...
have fun and think about donations if u use DL.
14 years 9 months ago #3950 by blixlab
Thanks,
I think the device Id issue is that qlab is "0" by default. All working good now, many thanks and ill let you know how i get on...
Time to create page: 0.161 seconds
