- Thank you received: 1
Arhtnet don't concect windows Xp
- vbs
11 years 11 months ago #8821
by vbs
Arhtnet don't concect windows Xp was created by vbs
I am trying to connect a Entec node to Dlight runing windows Xp.
It is recovering the node but if i start the server it shows waiting for 3 seconds but nothing happens.
Any idee??
Regards Vincent
Any idee??
Regards Vincent
11 years 11 months ago #8826
by aroom
Replied by aroom on topic Arhtnet don't concect windows Xp
check the ip adress of your node. you may have to switch the "BroadCast ArtPoll" from 255.255.255.255 to 10.255.255.255 or 2.255.255.255
check you firewall
check that both ip adresse from the node and from the computer are different
check you firewall
11 years 11 months ago #8833
Replied by sl1200mk2 on topic Arhtnet don't concect windows Xp
Hi,
for example:
computer: 10.0.0.50 (submask 255.0.0.0)
node: 10.0.0.51 (submask 255.0.0.0)
computer: 192.168.1.50 (submask 255.255.255.0)
node: 192.143.200.20 (submask 255.255.255.0)
(this one is not defined by artNet draft that specify 10.x.x.x/2.x.x.x IP range, but it works)
also don't forget to select 'available' at node level before starting the artNet server.
that's true but keep in mind that both computer and node address must be on the same IP range.check that both ip adresse from the node and from the computer are different
for example:
- vbs
11 years 11 months ago #8841
by vbs
Replied by vbs on topic Arhtnet don't concect windows Xp
Hi
Thanks for your reply.
Putting the ip adres in the Same range works, thanks
Recards Vincent
Recards Vincent
Time to create page: 0.137 seconds
